![]() | Home > Technical > I think I have a fooked turbo |
So it's a Java Blick all show no go RRS then....................................... |
BIRDY Member Since: 04 Nov 2006 Location: UK Posts: 213 ![]() ![]() ![]() |
It still runs ok just got this annoying noise worse when cold engine. Sort of disappears then but can be heard at slow speed through towns and stuff when the turbo is cooler and not workin so hard. Trust me to have another problem huh!! ![]() ![]() Ducati 1098S for the road and track and KTM 250EXC smoker for the mud. |
Bad luck mate... one of the great things about the TDV8 is that it doesn't have that dieselly note to it... |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
I have experienced a similiar problem with the steering pulling to the left and steering wheel off centre. Dealer found the alignment was out of spec as delivered from LR. Even then it took several alignment attempts with the dealer sending it to another garage in order to try different alignment equipment. Even then it still wandered to the left slightly. I have now changed the front wheels side to side and ............. problem solved. I think the original fault caused a tyre wear problem which in turn caused the car to drift to the left. This changing of the front wheels side to side, to cure this pulling problem, is commonly used by Porsche dealers and has worked for me previously.
Its a swirswirswirswirswirswir noise?? Gets faster and more high pitched as the engine revs rise. They say they fitted a new water pump cos they thought it was that but no. When I drive it first thing in the morning its at its worst, High revs say motorway work you cant hear it. Car is booked in 9th Jan for 15000 service and I have instructed them to sort all things out!! Car has pulled since new and supposadly had several allignments done. I do have a printout now of the settings. i would have assumed they would have tried swapping the wheels over but with my dealer who knows?? ![]() ![]() Ducati 1098S for the road and track and KTM 250EXC smoker for the mud. |
Birdy a few folks on here have found that "fixes" are not shared around the dealership service bays and have printed out the fixes that others on here have found have worked, I know it sounds carzy that we have to tell the dealers how to fix problems but often it is a case of handing the service manager a heap of printouts from the forum................................. The service manager at the local dealer even admitted to me that they often don't have time to be looking at the GTR website to see what the latest TSB's are, they arrive by email from LR, get printed out and filed and that's the last of it.............................. often it is us, the owners, that keep the dealer's technical dept up to date! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I gave them the print out off here about the knocking steering and the settings for the geom!!! Bit of a joke when I have to tell them whats wrong with my car?? ![]() ![]() Ducati 1098S for the road and track and KTM 250EXC smoker for the mud. |
Yeah, it is but at least they don't just thrown them in the bin (generally). |
ginger Member Since: 03 Nov 2007 Location: Home Posts: 25 ![]() |
Birdy I recall you had a power upgrade on the car....maybe the noise has something to do with that? |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
I'd be very careful about posting which performance upgrades one has had done on here. You just never know which LR employee is reading and posting or how it might affect your warranty in the future. |
My car is standard I never had the re-map done. ![]() And if I had it would be an easy way of getting out of another crap item fitted to my car. A bearing can be faulty at any time. Nothing to do with re-maps faulty parts...I`ve had a few others. ![]() ![]() Ducati 1098S for the road and track and KTM 250EXC smoker for the mud. |
Pyndon Member Since: 04 Dec 2011 Location: Lancashire Posts: 3 ![]() |
Birdy,
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
i have the sam noise, but i think its thev aux belt at the front, wd40 at the belt and it stops temporarily, driving me mad..
No I'm thinking exhaust valve, waste gate or something. done the WD40 on the belt and it makes no difference, still there. Birdy still around? He probably has the answer if he got it sorted? |
