Home > Technical > DVD troubles |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Know this is silly but you are loading them in to the mag in the boot right and not the dash? RRS TDV6 Gone but still around
Sat Dec 15 2007 11:08pm |
berommen Member Since: 15 Dec 2007 Location: Roeselare Posts: 11 |
Yes , artwork facing up, evreything like it should be.Tied several different DVD's. |
Sat Dec 15 2007 11:23pm |
Not sure sorry never seen that message myself!
Sat Dec 15 2007 11:26pm |
I wonder if one of the cables has been disturbed and might loose or unplugged - have you checked all the connections in the boot? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Dec 16 2007 9:48am |
I'm not shure about that , they are not easy accesible. I guess I better take the car to my dealer to check that out. Thanks for the reply's. |
Sun Dec 16 2007 8:35pm |
Keep us updated please RRS TDV6 Gone but still around
Sun Dec 16 2007 11:07pm |
Just a thought...
Sun Dec 16 2007 11:31pm |
Makes sense Bobby
Mon Dec 17 2007 9:59am |
The car is a Belgian car and I tried 10 different dvd's with the european region code.I have my car back tomorrow evening, I hope they(dealer) found the solution. I will keep you informed.Thanks for the reply's. |
Tue Dec 18 2007 10:12pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Probably too late, but this is from an old DVD troubleshooting bulletin.
Check to make sure you are not in the wrong video format using the remote (e.g. NTSC and trying to play PAL encoded discs) as per bold note above... It may be as simple as that. The On/Off button is the small one on the upper left side of the remote. Good luck, keep us posted! |
Wed Dec 19 2007 7:18am |
Hi. Today I got my car back from the dealer. They can't give an answer to the problem with the DVD player.So they contacted land rover and an expert will come to the dealer and will check out what is the problem. I will keep you posted but I have the impression that this will be a difficult one... |
Thu Dec 20 2007 10:53pm |
For Heaven's Sake, what more is there to "check out", I wonder? The DVD changer or RSE module don't work, put new ones in and get it over with! This "We're flying in an electronic warfare expert from London" crap sound like French for "We couldn't take a look at it but don't have the balls to tell you and hope you will go away now" to me, I've heard it before... Anyway, I assume you have tried the suggestions in the above bulletin on your own already? Can you imagine if you were able to make the thing work in your garage? They'd have to cancel the James Bond arrival!
Thu Dec 20 2007 11:02pm |
Fri Dec 21 2007 10:25am |
"• Press and hold the On/Off switch at the side of the remote control to
Sun Dec 23 2007 11:03pm |
