Home > Maintenance & Modifications > Slight Knocking Noise/Sensation felt through Steering Wheel |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
This is all interesting and as I previously mentioned I am experiencing a knocking/vibration/clunk - feel through my steering column/wheel I notice it most when tootling around town & doing plenty of shuffling around in car parks etc. Think I will make a call to my dealer soon re this.When my car was last in for electrics/fix I mentioned the problem 'm having with S/column ( they tightened the pinch bolt ) and told me LR were aware of this problem. SO obviously I still havn't got mine fixed properly then.
Sun Feb 12 2006 5:23pm |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Seems like things have developed slightly, the knock sound is back and after having the car on the ramps at work it appears the driver and passenger side wishbone bushes are all worn badly. This has got me thinking that with almost 11000 miles on the clock that I may have a major problem somewhere the car is going into the dealers again Saturday morning to have the bushes replaced but I am having doubts as to whether the problem will be back again. I don't think a car that is six months old and with not alot of miles on it should be needing this type of work carried out. I can appreciate some teething problems but these are major steering components Its out there somewhere. Second V10 Treg on the drive at the moment. |
Wed Feb 22 2006 10:45am |
Please keep all posted & up to date on the outcome of this Biggles.
Wed Feb 22 2006 11:00am |
JASON Member Since: 24 Aug 2005 Location: GLASGOW Posts: 46 |
I too occasionally get this sensation; dealer said it was a brake pad moving slightly as they are supposed to. Will get it checked again. Rimini Red HSE (D).Gone but not forgotten!
Wed Feb 22 2006 10:51pm |
Well the car went into the dealers and the problems are still there, they repaired the handbrake whine which apparently has affected a few discovery 3s but mine is the first sport they have had to perform the modification on.
Mon Feb 27 2006 9:58am |
frizz Member Since: 07 Jun 2007 Location: ashford kent Posts: 28 |
Persuader,
Mon Jul 09 2007 4:00pm |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 |
There are several different knocks that can come from the front. There is one from the column itself. There is one that comes through the steering when the lower column joint is worn. There is an issue with some vehicles as you say with ball joints. The wishbone bushes need the pre-determined play so when the suspension goes up and down it does not twist the rubber bush causing premature failure. - Well thats the idea. As for the air compressor the dashboard would indicate if it had not reached its correct height. At the moment I am re-calibrating my pre-set normal height at all different heights with the diagnostic tool to see where i get the most or least knoking, then looking into this arc system. I am short of time at the min due to training master technicians, but as soon as I have any answers I will post them for you.
Tue Jul 10 2007 7:54am |
Darren Member Since: 17 May 2007 Location: Weybridge Posts: 13 |
There is a recall on the disco 3 for this knocking fault with the column which requires replacing. My sport has been in for this and when they checked the part numbers for the columns they were the same as the disco 3 so they replaced it. |
Tue Jul 10 2007 8:41pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
So is there a recall on the RRS - does anyone know |
Tue Jul 10 2007 10:05pm |
No there is no recall on the RRS but the later vehicles have the later steering rack on with the damper that was mentioned earlier in this thread. It can also be fitted to reduce steering vibration on the earlier cars I beleive. I think we all need to be aware of all types of noises that are present at the min so as not to get confused. The loud grinding noise heard when turning on full lock when cold is normally the steering lock stops and it normally does it when the suspension is still in entry mode. Any chattering noise or un-even feel in the steering can be the steering column or the lower column joints, on any slight vibration or wheel wobble you might need the modified rack mentioned above. The Dynamic Response knock that is called Characteristic is defined by driving at around 20mph on smooth tarmac, then snatch the steering wheel one way then the other- the harder you turn the stering wheel the louder the knock. Then switch the vehicle off remove the battery cover and you will find a long fuse box next to the battery. Remove the fuse box cover - 2 rows of fuses on the right hand side as you look from the front of the vehicle and a lot of relays on the left. The row of fuses that are nearest to the relays and furthest from the wing, count back from the windscreen end including the fuses and the empty slots to the 5th fuse you will find it is 15amp. Pull this fuse out and close the bonnet. Start the vehicle, you will notice the red light on the dash a picture of a car with 2 arrows above it, this means the DR system is no longer active. Now carry out the same test at 20mph, You will find when you snatch the wheel the noise has gone. Stop the vehicle and replace the 15amp fuse. Replace the fuse box cover and the battery cover. Start the vehicle up and you will notice the light has extinguished- carry out the test again- the noise has returned. This is the characteristic noise mentioned in the technical service bulletin. I hope this helps You don't stop playing because you get old, You get old because you stop playing.
Thu Jul 12 2007 8:35am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
My car was returned to the dealer on Monday, and inspected today by area technical manager. He agreed the car was more noisey than it should be, and that other than all the other parts which had been changed, the noise was coming from the Antiroll system. My car has had, column, rollbar and mountings, drop links, two bottom ball joints and some sort of damper already replaced. When the anti roll bar were disconnected, the noise went away, re-connect and its back. Tomorrow they are fitting two new drop links, and 'bleeding' the suspension system again. If that does not resolve the noise, they want to take it back to the factory to try other parts Have told them to go and that the only way the car is going back to the factory is if I no longer own it. They also had no explanation why all four tyres were so badly worn after 4000 miles, and made no comment about the fact that I had been driving about with incorrect tracking since March. They had adjusted the ride height as they could not get the car into spec, now it looks like its in off road mode all the time. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Aug 01 2007 9:35pm |
chris Member Since: 27 Aug 2006 Location: south Posts: 37 |
I tried the test "Nutty Nige" has written above.
Fri Jan 04 2008 2:20pm |
