Bobby
Something on the Mode switch from an older P38:
MODE SWITCH
In High range, the mode switch is used to select ’Sport’ mode.
In Low range, pressing the same switch selects ’Manual’ mode.
Pressing the switch a second time returns the gearbox to its normal operation.
’Sport’ mode
When accelerating in ’Sport’ mode, gear changing is delayed to make optimum use of the engine’s power. Select when increased acceleration is required, or when negotiating long inclines or twisting roads. However, you should be aware that driving in ’Sport’ mode will increase fuel consumption.
To select ’Sport’ mode, press the ’Mode’ switch once whilst the gearbox is in High
range (the message centre will display ’S’ along with the selected gear, eg.’S3’).
’Manual’ mode
Press the mode switch whilst the gearbox is in Low range to select ’Manual’ mode; this enables the transmission to function as a manual gearbox, providing maximum vehicle control and engine braking - ideal for use in severe off-road conditions (the message centre displays ’LM’ along with the selected gear, eg.’LM3’).
NOTE: Changing from High to Low range (or vice versa) will automatically cancel ’Sport’ or ’Manual’ mode. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Sun Dec 02 2007 11:30pm |
