Home > Technical > Accessing N95 address book via BlueTooth
Page 2 of 3 <123>
UPDATE - It Works !
OK - so I can now happily confirm that the software I have insatlled on my Nokia N95 [ see beginning of thread] works 100% OK in the RRS... I tried it today at the Coventry meet in Josh's RRS ... within less the a minute I had my full phonebook in his car over bluetooth Thumbs Up
Post #145628 Sun Nov 18 2007 5:07pm
j8keyboy
MDP - I've just downloaded the contacts app to my N95 and started the app and it just says 'Processing' for ages - is this perhaps due to the 300 or so multiple contact entries stored on my phone? What exactly happened when you transferred your numbers over?
J8ke
Post #146585 Tue Nov 27 2007 10:44am
With a 2005 RRS - you may need to get the software/firmware update done on the bluetooth system at your local LR dealer
I had the same problem with my wifes n95 in her TT [ old software 2006 ] as my Audi is 2007 & works OK
The phone was tested at the last RRS meet in Cov in a new RRS and worked a treat ....
hope this helps Thumbs Up
Post #146594 Tue Nov 27 2007 11:54am
j8keyboy
I've already got the latest software/firmware update on my RRS. I get the 'Processing' message for ages even when I'm not even connected via Bluetooth to the car Bluetooth. How may contacts do you think you transferred over?
Post #146599 Tue Nov 27 2007 12:13pm
Not sure? but must be in the region of around 150 - 200 plus .... I get each contact with a seperate entry for mobile - home - business etc .... so even more entries when they appear on the RR Sports screen.
You could try " back up on PC " then add just one number to your phone ... try that out..... ? If that works with only one entry on your phone - you know its down to the size of your phone book entries. If not.. ??
Post #146603 Tue Nov 27 2007 12:43pm
j8keyboy
It sounds as though the no. of entries shouldn't be an issue then - I'll give another try later and if not, as you suggested, just try with 1 entry.
Post #146605 Tue Nov 27 2007 12:59pm
Either that ...... or get your LR dealer to re-check the software / upgrade that they say they have done. The factory software upgrade is supposed to give you the same level of bluetooth connectivity as a new 08 model year or even the newly 08.5
Post #146618 Tue Nov 27 2007 3:06pm
j8keyboy
I had the factory upgrade done about 2 weeks ago though so that was before the new TSB00095...29/10/07 bulletin.....DOH unlucky for me!!!! I tried the contacts push again but it still just hung - I will try with just one contact hopefully tonight......I really hope I can get this working as opposed to spending £100 or so for the stealer to update the Bluetooth again!
Post #146622 Tue Nov 27 2007 3:47pm
I think its sounding more like a software re boot/upgrade is needed Confused
Post #146628 Tue Nov 27 2007 3:58pm
j8keyboy
But if I've just recently had the RRS BT updated and my N95 is all up-to-date then surely this should be working as my RRS software version is probably the same as Josh's TDV8 is it now?
Post #146632 Tue Nov 27 2007 4:19pm
I would have thought so - thats the whole point of the software upgrade Neutral
Post #146633 Tue Nov 27 2007 4:24pm
j8keyboy
What was the exat software version of the N95 - you can obtain this by typing: *#0000#
Post #146635 Tue Nov 27 2007 4:38pm
Mine is V11.0.026 17-04-07 RM-159 Nokia N95 [65.01]
On O2
Post #146638 Tue Nov 27 2007 5:07pm
Mine is v12.0.013 i have the latest version
looks like v20 will be the way to go when/if they release it
http://www.allaboutsymbian.com/forum/showthread.php?t=58226
I hope they do Thumbs Up RRS TDV6 Gone but still around
Post #146650 Tue Nov 27 2007 10:00pm
sid
England 2008 Range Rover Sport TDV8 HSE Java Black
Version 20.0.015 released 26/11/07
seems to be working ok. Thumbs Up "I want to die peacefully in my sleep like my grandfather.....
Not screaming in terror like his passengers."
Post #146651 Wed Nov 28 2007 12:08am
Page 2 of 3 <123>
