Home > General > Vibration on front wheels if i upgrade to 20's TDV6 2005 |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
I've never heard of anyone complaining of this before. As long as the wheels are balanced properly you should be ok.
Mon Nov 26 2007 3:19pm |
We haven't heard of this for a long time, but it might be to do with the damped/undamped steering racks that were being fitted back in 2005. If you search the site for "steering rack" - you should be able to find the relevant info. Warranty job so no need for panic
Mon Nov 26 2007 3:32pm |
I notice your's is a 2005 model.. it just might be one of the earlier ones without the 'dampened' steering racks. They gave alot of trouble, especially to those upgrading to 20's.
Tue Nov 27 2007 2:58pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
There is an ancient TSB about this, see below. Based on my experience (I often run on 21" aftermarket rims, with a non-damped steering rack and without the slightest vibration, and I am not the only one...), the TSB is a bunch of baloney and it was LR's early attempt to brush off some steering vibration complaints, which people eventually kept experiencing even on cars fitted with damped steering racks, regardless of rim size. However, the TSB means that, if your steering does vibrate and you have non-damped gear, which is likely if you have an early build RRS, your dealer doesn't have to do a thing about it, he will just hand you a copy of the bulletin and send you on your way.
The bulletin illustrations referred to are the same ones that Bobby linked above. |
Wed Nov 28 2007 7:21am |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 |
Hi all,
Tue Nov 11 2008 2:26pm |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
had 19 inch standard on our 04/2006 and have 20 inch Stormers since 1,5 years - its just a little bit more firm with the 20 inch that's all
Tue Nov 11 2008 2:39pm |
That's exactly the same firt reg as one car I was acutally offered this morning which does look good (except from the standard wheels which I am going to change immediately if I will take this car ).
Tue Nov 11 2008 3:06pm |
i have no clue...
Tue Nov 11 2008 3:22pm |
So no one knows?
Wed Nov 12 2008 6:49pm |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 |
Ive just put 20"SC wheels on my 2005 RRS and removed the 19" wheels with no problems.
Fri Nov 14 2008 12:36am |
