Home > Technical > RRS Diff. lock |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 |
Hi
Wed Jul 27 2005 7:19am |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
Asked/answered elsewhere. Yes, rear locker is optional. (FYI: It doesn't make a huge difference and is probably a waste. RRS/Disco 3's Terrain Response is very capable with or without.) And no, you can't control it manually. TR takes care of it. |
Wed Jul 27 2005 8:57am |
Quasimoto Member Since: 27 Jul 2005 Location: Middleburg, VA Posts: 34 |
I did some rigorous off roading in my week-old HSE this weekend, and found it fascinating to watch the "4x4 mode" on the display switch on the center and rear diffs at different times. For some reason I expected the the rear diff to lock less frequently than the center, but they both locked (together and independently) about the same amount. Though at times it appeared the rear locked more frequently and for longer periods. -QM |
Mon Aug 01 2005 3:53am |
Thanks for your opinion. just I like to know what exactly 4X4 information
Sat Aug 06 2005 8:49am |
Rear Differential Lock
Sun Mar 12 2006 9:57am |
On the 4X4 Info Display, red is locked and green is unlocked. Yes, Terrain Response controls the locking differentials. If your vehicle doesn't have the rear locker fitted, the rear icon will still be displayed... but it should just stay green at all times. |
Sun Mar 12 2006 10:17am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
It shouldn't light up if its not there. My dealer said if it lit up then I'd got a freebie in error. Can't beleive that. TDV6 - gone
If you climb underneath the vehicle and look on top of the rear differential, you might be able to see an attached actuator with wiring loom... that won't exist if you don't have the rear locker option. If you are lost, ask your service department to verify.
Sun Mar 12 2006 10:20am |
I don't have it on mine but when I used the local LRE V8 at the ofroad centre I was surprised how soon and regularly it cut in too. I think like other folks say, unless you are doing the G4 Challenge in your car you will probably never need to use it for real! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Mar 12 2006 10:51am |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
It definitely helps in traditional 'cross-axle' situations - we've had rear-diff lock equipped and non-equipped D3's head-to-head and the one with difflock sailed straight through the cross axle whereas the non-equipped one had to be encouraged through using the traction control. Like this site? Buy some RRSPORT goodies to show your support! |
Sun Mar 12 2006 11:16am |
avus Member Since: 31 Jan 2006 Location: chi-city Posts: 16 |
can the rear diff be installed afterwards? |
Sun Mar 12 2006 12:00pm |
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 |
Sounds familiar |
Sun Mar 12 2006 12:05pm |
Sun Mar 12 2006 12:09pm |
Not that we know of so far, although it's not been attempted Like this site? Buy some RRSPORT goodies to show your support! |
