Home > Technical > Sat nav destination input not working
j8keyboy
I've reset my sat nav and now am unable to enter destinations using the post code search - I'm only able to input numerics and not letters, what has gone wrong!?
Thanks,
J8ke
Post #144213 Mon Nov 05 2007 9:55am
MAW
Diff to know without being on front of it...
Dealer !
What do you mean when you say reset it - what have you done?
Post #144222 Mon Nov 05 2007 10:57am
j8keyboy
There was a button on the sat nav saying reset and as I've only just got the car I thought it would be a good chance to reset the sat nav....wish I had left it alone now! In for a service tomorrow so I'll let them take a look at it!
Post #144223 Mon Nov 05 2007 11:05am
Hmm, don't remember ever seeing anything like that reported (or in my own). Like MAW says, get in front of the dealer. Let us know what it was all about! Thumbs Up
Post #144224 Mon Nov 05 2007 11:07am
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Check what region is loaded. For example, french have numeric postcodes, and when in 'FR' setting on the sat nav, you can only put in numerics
Post #144231 Mon Nov 05 2007 1:03pm
j8keyboy
Ok that makes sense - How do I change the region setting then?
Post #144232 Mon Nov 05 2007 1:05pm
bermyandy
Top of my head cant remember, but definitely covered int he manual
Post #144233 Mon Nov 05 2007 1:06pm
j8keyboy
Yeah the manual....not had chance to read through it all yet - that's tonight's task!
Post #144234 Mon Nov 05 2007 1:09pm
Tim in Scotland
OK here goes for my 2008MY
Switch on ingition,
Press the agree button on the screen
Do not use the touch screen , press the right hand "hard" button on the screen base
the screen will change to show 4x4 info, routing and on the right "settings"
Press the settings soft key onscreen
then select language and scroll up to English and select it
exit by pressing in the left hand "hard" key at the screen surround to return to the navigation screen.
Hope that helps you 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #144238 Mon Nov 05 2007 1:21pm
MAW
Under enter destination - the map will highlight where it thinks you are (in green i think) touch on UK, green will shift then destination format for that region should be corrected - going from memory but fairly intuitive as I recall.
Post #144239 Mon Nov 05 2007 1:22pm
Ah yes, that rings a bell... and once selected the initial country becomes the default until you reset. I remember thinking when I first used it that it would be a right kerfuffle having to choose UK as my destination country every time I wanted to enter a destination.
Strange though that the factory default setting would NOT support the UK postcode format Confused
Let us know if that fixes it! Thumbs Up
Post #144243 Mon Nov 05 2007 1:53pm
j8keyboy
As suggested by various people it was just a matter of selecting GB on the Eurpope map - easy fix now that's what I like - thanks 2 all 4 your help!
Just dropped the motor off for a service and have been quoted the following prices - any idea if they are OK?
- Bluetooth upgrade = �99.88
- Sat Nav upgrade = �186.56
Regarding the Sat Nav upgrade, I've seen discs available on ebay so may go down this route, however for the Bluetooth upgrade is this a main dealer only upgrade?
Post #144336 Tue Nov 06 2007 9:23am
The costs are on the money. Before you go with the BT upgrade check your phone is compatible. 2005 Zambezi TDV6 - Gone but not forgotten
Post #144337 Tue Nov 06 2007 9:29am
j8keyboy
I've a Nokia N95 which I told the service guy so I presume it's compatible then else he wouldn't of quoted me. Is there no way of upgrading the Bluetooth myself - is it just a DVD that is needed?
Post #144339 Tue Nov 06 2007 10:11am
No, it's a hardware & software upgrade so dealer only for 99% of people unless you happen to have the relevant kit & caboodle yourself.
The N95 does work with the upgraded PTI as far as I know, but with the limitation that you only get the first entry of a contact in your phonebook sync'd across. You may also have to activate the remote SIM option on the phone. This just seems to be the way it works - it's not just LR, but the BMW system does the same so there's obviously a wider issue.
Post #144340 Tue Nov 06 2007 10:34am
