Home > General > Multi height tow bar removal
j8keyboy
All,
The RR Sport I've just bought has the multi height tow bar however I want to remove this - any idea how, is it just a matter of undoing the 2 bolts that are bolting the metal strut to the chassis then I assume using the supplied keys to remove the actual hitch?
I like the idea of having a towbar having only for the odd occasion that I need it, hence I may replace this towbar with the detatchable towbar - anyone want to swap?
Thanks,
J8ke
Post #143958 Fri Nov 02 2007 3:36pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
I don't think you'll get many takers for the swap.
But thanks for asking. Laughing Laughing Laughing Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #143960 Fri Nov 02 2007 3:43pm
Tim in Scotland
Wouldn't swap my detachable tow hook for anything, especially not a multiheight one. Looks like you could be on a trip to ebay j8keyboy, both as a buyer and a seller! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #143962 Fri Nov 02 2007 3:48pm
j8keyboy
OK so I take it the detatchable tow bar is more desirable then!
Well how do I go about removing this eyesore then!?
Thanks,
j8ke
Post #143990 Fri Nov 02 2007 4:29pm
Texstar
Remove it as you stated, take the 2 bolts out of the chassis (you may have trouble re aligning these when they go back in, it may help to loosen the nuts on the outboard side to allow the part inside chassis rail to move a bit.), loosen the nuts and bolts at the bottom end of the struts or remove them completely,and then use key and unlock, pull out and turn the green knob on the part that connects in the receptacle and drop it down, ( watch out though, its heavy).
Post #143996 Fri Nov 02 2007 4:39pm
Tim in Scotland
j8keyboy wrote:
................how do I go about removing this eyesore then!?
I don't think I have ever seen one on an RRS, the local farmers have them on their D3's around here, I would imagine that you will have to get underneath the car to see where it is bolted onto the rear subframe/ chassis.
Have you tried asking over on the Disco3 technical Forums? www.disco3.co.uk 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #143997 Fri Nov 02 2007 4:43pm
Pelyma
Censored I've just bought one for my D3, if you want to tow and use a bike rack you need the multi height bar. I can sell you a swan neck bar though!
Post #144011 Fri Nov 02 2007 5:21pm
j8keyboy
Once I get the tow bar off how much should I expect to sell it for on ebay do you think?
Also, I've the dog guard thingy in the boot that I will probably also sell - how much do you think for that?
Thanks,
J8ke
Post #144039 Fri Nov 02 2007 6:25pm
Pelyma
The removal is easy, just make sure you have the key. It is 2 bolts and the locking mechanism in the reciever. I paid over £200 for mine new, they don't come up very often. I'd try posting on the D3 site first.
Post #144041 Fri Nov 02 2007 6:49pm
