Home > Off Topic > motorise a garage door
uk rrs
hi guys, i have a canopy style garage door & want to motorise it , any recomendations ? oh & i want to fit it myself any drawbacks Confused
Post #141687 Mon Oct 15 2007 11:41am
It's doable, but not entirely easy... especially with canopy doors. A neighbour of mine self-installed his last year and spent most of the time tearing his hair out about how the door's running tracks weren't entirely free-running (which apparently they need to be, the motor overheats if it has to push against resistance all the time).
Post #141688 Mon Oct 15 2007 11:45am
kam100
I've got a canopy door on my house, and had a motor fitted last year.
Took a bit of research.. i used these guys fitted them for me, in about 1.5 hours..
Cost me around £400 fitted.. no problems whatsoever with the unit..
its not 100% free running, as it stops about 75% of the way up, the motor steps up a gear then suddenly its at 100% up.. but you don't notice it unless you're watching.. im either driving up to the house/away at that point, so don't care..
http://www.kingsburygaragedoors.co.uk/2411/frames.php
Not the best website, think i was given their card by someone.. and they had the quickest lead time..
Post #141704 Mon Oct 15 2007 1:55pm
We had motor's fitted to the garage doors that come with the house when we got it they packed up and we just spent 3.5K on new doors and motors much much more secure and no gap's so no more s**t being blown in to the garage from the street
Can't remember what called now will find out and let you know RRS TDV6 Gone but still around
Post #141708 Mon Oct 15 2007 2:37pm
Tim in Scotland
I have a motorised canopy door too, but these days I cannot get the car inside the garage! It was installed professionally for about £600 15 years ago. The only problem I have had with it is the radio link/ transponder going haywire and also when some of my neighbours (after ridiculing me for years for being a lazy sod) got them fitted it transpired one of them picked the same 4 numbers in the code so my door would open when they opened theirs and vice verse, but that was easily solved. I have now had 3 different radio activators and when the last one gave up I didn't bother replacing it and just use the emergency button in the garage when I wnat to open the door. It will stay like that until I get a smaller car that will fit under my door, the wideth isn't a problem just the height!
As Jay says one thing I can recommend having as an extra is the heavy duty seal instead of the standard one - I don't get any leaves or rain blowing under the door in bad weather like I used to with the old manual door that I had. Also it has never frozen to the drive or stopped when we have had heavy snow fall, I thought this would be a possiblity, but my opener has an anti trapping device so as soon as it comes up against an obstruction it stops and returns to the position it started from so you don't burn out the motor. My door is a herringbone pattern wooden one in a steel frame supplied by Garador the original motor was made by Stanley but when the first transponder gave up I replaced the whole works with a screw drive as the Stanley one was a clunky chain drive that needed maintaining every 6 months
If you already have an up and over/canopy door that runs really freely then it isn't that difficult to fit the motor yourself - you used to be able to buy the kits from B&Q 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #141750 Mon Oct 15 2007 4:27pm
