Home > General > What do you fill up with |
ayates Member Since: 08 Jun 2007 Location: Houston Texas Posts: 369 |
Shell V-Power and thats it ..... compared it over others and it does feel different. I also have a good friend that is with Shell in the fuel development area and we have had many an hour discussion about the differences over bog std fuels and it would seem that there is a difference if not just in engine wear. Brit across the Pond
Sun Oct 07 2007 4:40am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
I use BP Ultimate diesel.
Sun Oct 07 2007 9:55am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
I tried the BP Ultimate Diesel and Shell V-Power and there is no difference in MPG whatsoever and TBH I also didn't feel any other difference either (except my pockets were lighter)!!
Sun Oct 07 2007 1:59pm |
SteveWilliams Member Since: 05 Aug 2007 Location: Swindon Posts: 138 |
That is part of the reason I asked the question. Do these expensive fuels actually make a difference although they do normally say it takes a while to notice the difference.
Sun Oct 07 2007 3:46pm |
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 |
Never noticed any difference with BP Ultimate but Shell V-Power definitely makes my engine run smoother |
Sun Oct 07 2007 3:50pm |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
a little bird once told me some petrol stations put the same fuel in both the std and super unleaded tanks on occasions due to logistics |
Sun Oct 07 2007 4:38pm |
What Car has an article on the subject at moment. I flicked through it in a shop. But it seems to be petrol biased.
Mon Oct 08 2007 7:19am |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
I have kept careful MPG records for mine.
Mon Oct 08 2007 8:03am |
Kuke Member Since: 05 May 2007 Location: Zurich Posts: 99 |
the standard 98 octane is the best compromise i think. there's the cheaper 95 ocane available (eeew dirty ), but the engine just runs much smoother with the 98. never tried the 100 ocate ones, will try the V Power next time. (get the chance every other day greets to the green party )
Wed Oct 10 2007 10:47am |
it was from a very good source - it wasn't common place however sometimes demand and vehicle logistics demanded it |
Wed Oct 10 2007 12:35pm |
MikeP Member Since: 18 Dec 2006 Location: Buckinghamshire Posts: 258 |
There was an article in Autocar the other week - Last week I think and they're tests proved from fuel alone that Mpg and obvious signs of improvement for the extra 8p is not noticeable HOWEVER they did not touch the engines and could measure any change on engine wear etc.
Wed Oct 10 2007 12:47pm |
Yeah... keep it for trackdays. Nobody needs to spend that sort of money on a tank of fuel!!
Wed Oct 10 2007 1:25pm |
A friend of mine has decided to run his BMW diesel on BP Ultimate diesel after using normal spec fuel. He reports that he is getting better Mpg and performance as a result of the change. TDV6 - gone
Thu Oct 11 2007 7:15pm |
