Home > Technical > Heated windscreen functionality
ayates
United States 2007 Range Rover Sport Supercharged Buckingham Blue
I had left the car outside over night the other day and in the moring the windscreen was fogged up so naturally I demisted it with the program button, this starts the fan and the heated elements front and rear. On the Rear screen I can see the hot elements clearing the screen, however the front screen didnt appear to have the same effect..... What should I see, anything ? or are the heated elements not working I wonder and its a trip across town to LR ? Brit across the Pond Wink
07 TATA (LR) RRS SuperVindaloocharged, Buckingham Blue, Stormers, TPMS, Sunroof, Rear Difflock,PDC front & rear, Privacy, Rear twin DVD, premium ice, mudflaps, premium Ivory leather, lined oak, PTI, Sat Radio.
Post #139819 Fri Sep 28 2007 10:30pm
Josh
Front heated screen dosen't show up like the back one. It just clears very quickly. TDV6 - gone
TDV8 - gone
Post #139830 Sat Sep 29 2007 2:44pm
Jimmy_75000
As Josh said, it does not show like the rear one because the heating element in the front one are much closer to one another then in the rear. Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #139896 Mon Oct 01 2007 7:18am
ayates
So say given the fact that the screen is misted up outside in the morning then I turn the screen on, are you saying I should see it clearing.... if so then I think its not working ???
Think I will jet it check out at the 1st service.... Brit across the Pond Wink
Post #139959 Mon Oct 01 2007 2:56pm
Yep, but it clears pretty quickly with the PROG button, especially if the screen has just got condensation on it. Even when the screen is iced up in the middle of winter, it's only 2 or 3 mins and it's clear enough to drive.
Post #139960 Mon Oct 01 2007 2:59pm
Ayates - I find the screen pretty useless in clearing mist, it works best for deicing the windscreen. 2005 Zambezi TDV6 - Gone but not forgotten
Post #139961 Mon Oct 01 2007 3:21pm
Josh
I usually hit the top right hand button (prog) on the console turns the lot on. After about 2 or 3mins minutes its clear as a bell and works well for misted up windscreen given that it is directing air at the screen as well as turning on the heated screen. Then I turn it off long before the prog has ran its course.
Takes a little longer when its iced up in the middle of the night when most members on here are asleep Yawn Exclamation TDV6 - gone
TDV8 - gone
Post #139988 Mon Oct 01 2007 11:30pm
