Home > Technical > Heater output under passanger seat
Jimmy_75000
Hello all,
Does anyone has a clue on how to access it? To make the story short, I have two marbles stuck in there rolling and clashing at every turn,break,acceleration....Getting me mad!
This heater output seems to be going down through the car, can't see it under the car....Any idea on how to get them out??? Pleaaassseee!!! Evil or Very Mad going crazy driving! Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #139327 Tue Sep 25 2007 6:56am
aljo
another rrs owner lost his marbles then ? Big Cry
Whistle
Post #139344 Tue Sep 25 2007 9:19am
Jimmy_75000
Shocked
Rolling with laughter I am sorry but still prood owner of all my possession!!!
My daughter dropped them... Range Rover Vogue ‘17 TDV6
Post #139348 Tue Sep 25 2007 9:33am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
That's a seat out job I'm afraid Jimmy.
You will need the dealership's assistance on this on. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #139382 Tue Sep 25 2007 1:31pm
Jimmy_75000
Big Cry
still gonna try a home solution tonight with a stick and some tape.... Range Rover Vogue ‘17 TDV6
Post #139384 Tue Sep 25 2007 1:35pm
Stick and some bluetack. Another way is a vacum cleaner with an adapted novel. 2005 Zambezi TDV6 - Gone but not forgotten
Post #139386 Tue Sep 25 2007 1:38pm
Jimmy_75000
Did try the vacum but no success there (for about 30 min yest'!, told you, this is getting my head!! Banging Head ) Range Rover Vogue ‘17 TDV6
Post #139387 Tue Sep 25 2007 1:42pm
TB
If you want to be really brave, you could take the seat out yourself. But do not disconnect the seatbelt, or disconnect any of the electrical harness while the keys are in the ignition. This will throw a fault code and play havoc with your SRS systems.
If you are thinking of removing the seat you may need to operate the seat backwards and forwards to access all of the seat bolts, once you have done this, remove the keys from the ignition and leave the car for two or three minutes so that all of the electrical systems shutdown properly. You should then be ok to disconnect the seat harness without causing any other problems. Obviously when refitting the seat, make sure you have made all the electrical connections before switching on the ignition.
And most of all, good luck. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #139388 Tue Sep 25 2007 1:51pm
Jimmy_75000
thank you for this information. If the stick/tape/blue tack mumble does not work, I guess I will have fun on saturday morning! Range Rover Vogue ‘17 TDV6
Post #139389 Tue Sep 25 2007 2:07pm
If you do take the seat out why not photograph the procedure? Good for future reference. 2005 Zambezi TDV6 - Gone but not forgotten
Post #139390 Tue Sep 25 2007 2:09pm
Good idea - get yourself a sticky in the M&M section Thumbs Up
Post #139391 Tue Sep 25 2007 2:16pm
Ian.Richardson
Have you tried getting up to 100 mph and then slamming on the brakes. Smile
Post #139392 Tue Sep 25 2007 2:21pm
aljo
get boobie -man to stick his lips round one of the heater vents and suck the marbles out ? Thumbs Up
Post #139393 Tue Sep 25 2007 2:25pm
Top tip! Thumbs Up Rolling with laughter 2005 Zambezi TDV6 - Gone but not forgotten
Post #139394 Tue Sep 25 2007 2:28pm
Jimmy_75000
i agree! But you would need to do that while driving in reverse otherwise they won't come out!
If I have to undo the seats, will take the requested pictures....
As mention earlier, tried the hover but no success there... Range Rover Vogue ‘17 TDV6
Post #139396 Tue Sep 25 2007 2:30pm
