Home > Maintenance & Modifications > Video In Motion - Cheaper Unit? |
xLusi0n Member Since: 12 Jun 2007 Location: Los Angeles Posts: 92 |
What's the difference between this:
Sat Sep 08 2007 4:50pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
The gnet module interrupts the image from the satnav feed to the front monitor and replaces it with its own input, to which you can connect pretty much any portable device that comes with an A/V out, including a backup camera if you want. It's basically a simple split of the same input from the satnav to the front monitor (I think you actually need to splice some wires.) The Nav-TV solution is more integrated, enabling the existing video feed from the RSE system to keep playing on the front monitor while the car is in motion (only if you have RSE, of course) and also enabling the "dormant" (at least in North America) TV input in our cars' infotainment software to obtain an additional input for other portable devices. |
Sat Sep 08 2007 7:06pm |
Doesn't RRUK's FFRR have the venturecam?
Wed Sep 19 2007 8:40am |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
S i think it's standard on the FFRR now? RRS TDV6 Gone but still around
Wed Sep 19 2007 10:27am |
Didn't have it on the Vogue I did the LRE in a couple of weeks ago... the instructor (in his sales spiel) said "you can get it fitted".... but not sure. I'll check on the features list...
Wed Sep 19 2007 10:35am |
Oh right it's an option on the TDV8 RRS TDV6 Gone but still around
Wed Sep 19 2007 10:41am |
That would explain it....
Wed Sep 19 2007 11:11am |
R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193 |
I installed one of these Gnet video in motion units in my RRS last night. So far it's worked perfectly. It only took me about 3 hours to fit and only had to splice a few wires. I fitted the box under the passenger seat easily enough. I had to splice into a 12v source in the centre console and into the aux aucio connector in the back of the car. I fitted the source select button and the IR diode in one of the cupholders in the centre console where I already have an Origin B2 speed camera detector device fitted. It's all very slick and works perfectly with my iPhone as the video input source.
Mon Jul 28 2008 12:41pm |
Nice work, R33
Mon Jul 28 2008 12:51pm |
Yes when I get a chance I will put some more words behind it and some pics. I meant to take install pics last night but I got too carried away with the install |
Mon Jul 28 2008 12:58pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 184 |
Vogue's should come as std with a DoggingCam (VentureCam),
Thu Jul 31 2008 2:42pm |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 |
Create a DIY thread |
Thu Jul 31 2008 5:28pm |
http://www.gnetcanada.com/navvideo-models-gnet_lr3.asp
Sun Aug 03 2008 5:49pm |
