Home > Technical > Supercharged with or without intercooler
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
Guys,
Just wona to know if the Supercharged engine in RRS has intercooler
as you all know turbo engines mostly having intercoolers at least in my Evo 8 I'm having one
Post #12975 Tue Feb 14 2006 5:16am
PaulB
Post #13007 Tue Feb 14 2006 6:46pm
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
Supercharged engines dont usually have intercoolers as the supercharger 'sucks' air rather than 'blows' air in a turbo set up and an intercooler would restrict air intake; even if it was technically possible to 'plumb' one in;-) Chips with everything
Post #13010 Tue Feb 14 2006 7:01pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
the Jaguar V8 engine in the sport is fitted with twin intercoolers, look under the engine cover !!
Andrew
Post #13017 Tue Feb 14 2006 8:42pm
Martin
Site Administrator & Owner
MINI Cooper S is supercharged and intercooled Cool Like this site? Buy some RRSPORT goodies to show your support!
Post #13046 Tue Feb 14 2006 11:23pm
JE Engineering
The SC Sport has 2 intercoolers, both coolers are located on top of the engine and are conected too a cold water circuit with a electric water pump and rad for cooling.
Post #13061 Wed Feb 15 2006 8:58am
LRtuning
Ahhh....so they are charge coolers...not just intercoolers?
I remember seeing a charge cooler first on on Vauxhall Lotus Carlton Smile
Got this info off the web for forum members...hope it explains it all
An intercooler is a device used on turbocharged and supercharged internal combustion engines to improve the volumetric efficiency and increase the amount of charge in the engine, thereby increasing power. The inter in the name refers to its location compared to the compressors; the coolers were typically installed between multiple stages of supercharging in aircraft engines. Modern automobile designs are technically aftercoolers because they appear most often at the very end of the chain, but this name is no longer used.
Turbochargers and superchargers compress incoming air, causing it to become heated. Since hot air is less dense than cooler air at the same pressure, the total charge delivered to the cylinders is higher than non-compressed air, but still less than it could be. By cooling the charge after compression, even more charge can be delivered, increasing power. Additionally, intercoolers help to increase the total amount of boost possible without causing engine knocking.
An intercooler is essentially a radiator tuned for high volume flow rates and the increasing density of the charge as it cools. Most designs use ambient air for cooling, flowing through the radiator core, and often collocated with other radiators for oil or cooling fluid. This approach is also known as Air To Air (ATA).
An alternate design, often referred to as a charge cooler, uses water or a water/antifreeze mix to cool the charge, then cools the water in a separate radiator. While heavier and more complex, charge coolers can often make arranging the rest of the engine much simpler. This approach is also known as Water To Air (WTA). A variation on this type of charge cooler substitutes a reservoir of coolant for the radiator, allowing the use of an icewater mixture that can bring outlet temperatures well below ambient air temperature even under very high boost pressure. Because of the limitations on the volume of icewater that can be stored and circulated, this approach to charge cooling is only practical for short durations, making it most common in drag racing and land speed record attempts. Chips with everything
Post #13062 Wed Feb 15 2006 9:00am
rrmad
2006 Range Rover Sport Supercharged Java Black
intercoolers in any language - of course the s/c has them
Post #13637 Sat Feb 18 2006 2:20pm
sportman
charge coolers sounds new to me ,thanks for turbochip
great explanation, Now which are more efficient air to air intercooler or Water To Air ones specially in hot climate like Dubai 45C plus Wink
Post #13690 Sun Feb 19 2006 6:18am
Speedinnovation
United States 2006 Range Rover Sport Supercharged Java Black
I've been researching on upgrading the supercharger bilge pump as I made a new pulley for the supercharger its gives me 2 pounds more boost I cant wait I will keep you guys posted I think if I can keep the intercooler cooler and run a bit more boost I should be fine
Post #13750 Sun Feb 19 2006 6:54pm
LRtuning
water to air are much more efficient and are always know as charge coolers Chips with everything
Post #13757 Sun Feb 19 2006 7:52pm
Speedinnovation
I completely agree they are more efficient and upgrading them abit can provide much more cooling especially if you want to add mods I sent you an email to your info@turbochip from jdiakis@yahoo.com
Post #13758 Sun Feb 19 2006 7:59pm
