![]() | Home > Technical > Airbag warning light & Fuel flap won't open |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 ![]() ![]() |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Yep it does seem stupid, Although judging by what TB mentions in his reply it looks lke there may be a manual work around. If this is the case then it's pretty bad that your dealer didn't know! - I'll check my car after work to see if TB is correct - Which of course i'm sure he is ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Your looking for a black plastic coated cable, about 4 - 5 mm in diameter.
SteveWilliams Member Since: 05 Aug 2007 Location: Swindon Posts: 138 ![]() ![]() ![]() |
Yep found it and will know what to do next time.
With a bit of luck, there won't be a next time. |
Have tried it a couple of times since it last happened and its been fine............... Off to France in a couple of weeks so will see how it goes. |
