Home > Maintenance & Modifications > Radio Message
KenD
England 2007 Range Rover Sport TDV6 SE Zambezi Silver
Radio Message
Hi All,
Just got a message on the radio screen when I turn the volume up, saying "Low battery mode".
Does anybody know what it means? Can't find anything in the manual.
Post #136055 Mon Sep 03 2007 6:03pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
When you turn off the engine and/or remove the key from the ignition, radio playback kicks down to "Low power mode" to conserve battery, limiting your max volume output to "+ 20" I think, versus the usual + 35. When you hit that ceiling, you get a little battery icon and "Low power mode" displayed on the radio LCD.
Post #136085 Mon Sep 03 2007 7:47pm
KenD
Hi Umberto,
Thanks for a quick reply.
I understand the logic of what you are saying re. battery conservation when stopped, but this happens when I'm driving and I turn the volume up. It showed at about level 18, after a little while it allowed me to increase the volume to 20. All very strange.
Post #136140 Mon Sep 03 2007 9:13pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Something wrong there Ken .... IMHO trip to the stealers needed RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #136144 Mon Sep 03 2007 9:18pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Smarticus is right, take it back to the stealers.
There is definately something wrong with your audio unit. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #136153 Mon Sep 03 2007 9:45pm
umbertob
Yeah, sounds to me like a loose contact or wire somewhere, the radio unit no longer detects the engine running and key in the ignition, and cuts off to low power mode. First time I've heard of that, keep us posted on what the dealer finds out, if the problem reoccurs (it's a Land Rover, so you never know...)
Post #136159 Mon Sep 03 2007 10:11pm
Mine did this last week ok now will see tomorrow RRS TDV6 Gone but still around
Post #136171 Mon Sep 03 2007 11:05pm
djsaad1
United States 2006 Range Rover Sport Supercharged Java Black
this happend to me once a while ago, has not happend since.
Post #136176 Tue Sep 04 2007 12:33am
KenD
Spoke to the stealer today. he says it's nothing to worry about, it's to do with conserving power as Umberto said. If you leave your key in the ignition, as I did, for about 5 mins before starting, it drops the power on the radio volume to about 18, 20. After the engine has started it takes a little while for it to revert back to normsl. He said it's to conserve power for the vital parts of the engine if the battery was low.
Seems to be OK now.
Anyway thank you all for your help.
Post #136267 Tue Sep 04 2007 9:00pm
umbertob
Sounds like he fed you a tiny bit of BS here and there (takes a "little while" to get back to normal... You got lazy electronics on your Sport? Mine goes back to normal volume a split second after I crank the ignition!) but as long as it appears to be OK now, it's all good. Smile
Post #136497 Fri Sep 07 2007 1:55am
