Home > Maintenance & Modifications > Psi
cowey101
Psi
I have just fitted a set of stormers with 295/40/20 tyres, can anyone let me know what the optimum tyre pressure should be for this set up.
Cheers Thumbs Up Java Black TDV6 HSE - Java Grandes Marques 1/18 - Ducati 749s
Post #135300 Thu Aug 30 2007 12:31pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Here in North America LR recommends the same pressure regardless of whether you run on 18, 19, or 20" rims: 38 psi front and 42 rear (cold). That's for fairly full loads, plus most of us are morbidly obese around here. Very Happy If you are often traveling solo, I believe you could safely run on 2-3 psi less than 38f /42r for a bit more comfort.
Post #135375 Fri Aug 31 2007 6:48am
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
Thats excellent Umbertob, i was going to ask the same question as Cowey, its save me the job Thumbs Up
Post #135411 Fri Aug 31 2007 8:18am
Cliff H
We all know Envoy is full of hot air Whistle Whistle Laughing
Post #135419 Fri Aug 31 2007 9:22am
cowey101
thanks for the info umbertob, poor E getting hassle again Whistle Java Black TDV6 HSE - Java Grandes Marques 1/18 - Ducati 749s
Post #135434 Fri Aug 31 2007 10:52am
ENVOY
Thanks Dale, im glad someone else has noticed how much grief i get Whistle Whistle
Post #135577 Sat Sep 01 2007 12:39am
