Home > General > mudflaps + 22 inch wheels
GIB 984
Hi Guys,
Has anyone put mudflaps on a HSE with 22inch wheels?
I am just about to order from Marshalls LR on ebay and thought I better ask the question!
Are there any issues and how easy are they to fit?
Cheers! Best Wishes
Gary
Post #132610 Mon Aug 13 2007 8:07pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
They are very easy to fit and will not create any issues with 22" wheels, since the overall diameter of the wheel will be (should be) about the same as the stockers. If you do have issues, you have bigger problems than just the mud flaps... Very Happy For the rear flaps you may need an offset Phillips screwdriver to reach certain screws between wheel well and tyre (clearance is minimal), and the front ones require that you cut a small section of trim on the inner edge of the wheel fenders. Other than that, it's a breeze.
Post #132616 Mon Aug 13 2007 8:29pm
GIB 984
Great - Thanks umbertob!
I'll go ahead and order them. Best Wishes
Gary
Post #132632 Tue Aug 14 2007 6:30am
