![]() | Home > Technical > Steering Vibration |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Oct 2005 RRS TDV6 Bluetooth, VR, Roof ![]() |
Whole steering rack. Tech bulletin is LTB00030v2 and the Steering Gear part number is QEB500470 for RH drives. Depends when yours was built, the tech bulletin only came out 15 Feb 2007, so your may have missed out on the new upgrade. RRS TDV6 Bluetooth, VR, Roof ![]() |
PS the Tech note says VIN range 5A900018 onwards if that is any help? RRS TDV6 Bluetooth, VR, Roof ![]() |
redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94 ![]() ![]() ![]() |
thanks lateral, mine ws built DEC 2006 so there is a good chance a new rack will fix it |
Glad to be of service ![]() ![]() |
Ecosse Member Since: 08 Jun 2005 Location: Grampian Posts: 12 ![]() ![]() |
Have had a very similar problem on an early model Disco 3 TDV6 - apparent with new tyres, had balancing rechecked, then dealer checked wheel allignment; claimed that all within spec but vibration disappeared. I as fairly certain it was an allignment type issue as vibration cane in at 55mph then disappeared after 60mph, but very annoying |
