![]() | Home > General > I've got a new phone/radio problem... |
USAGivGrn Member Since: 26 Nov 2005 Location: Omaha Posts: 24 ![]() ![]() ![]() |
I had a similar experience. I believe I turned off my phone from the handset, waited a minute or two and reconnected. The multiple line feature is not supposed to be operable without using the cradle.
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Call waiting is not supported through Bluetooth, only through cradled phones (I understand it may be a bandwidth limitation.) My phone behaves similarly to yours, if I pick up a second incoming call the system hangs indefinitely. So, I don't answer incoming calls anymore when I am already on the phone and let the second call go to voice mail instead. If you do/must answer that second incoming call and the system does freeze after you hang up, you can usually get the system back by disconnecting and re-pairing the Bluetooth link through the handset. However, each phone behaves differently and Call Waiting causes trouble 9 out of 10 times, regardless of what type of Bluetooth phone you are using. |
rweintra Member Since: 30 Jun 2005 Location: New York Posts: 70 ![]() ![]() ![]() |
Well, I have a cradle too, and just tried it with the cradle; doesn't work either. I tried hitting the menu button and going to "swap calls", but that didn't work. I hit the green paddle, that didn't work either. I don't know what to do now. I guess just let the second call go to voicemail. How annoying! |
tony Member Since: 26 Nov 2005 Location: alicante Posts: 5 ![]() ![]() |
I have the same problem exept sometimes my bluetooth will not connect
Just took a 6 hour drive in the RRS, and there is a new phone problem I am having. When the phone is in the cradle and someone hangs up, the "hang-up" paddle won't hang up the call. I have to take the phone out of the cradle and then snap it back in. How annoying! |
