![]() | Home > Technical > Transmission Fault - Traction Reduced! |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 ![]() ![]() |
It's a wiring loom problem...book it in to the dealer? Chips with everything |
avus Member Since: 31 Jan 2006 Location: chi-city Posts: 16 ![]() ![]() ![]() |
specifically, what type of wiring loom problem? is it incorrectly installed, or does it need to be changed completely? 235 miles on my rrs s/c and this message has showed up. i just turned it off, and restarted the LR -- message did not reappear. |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
Sorry, there is no "simple answer" to a fault like that... it could be many things. I know two people that have seen this error a few times in perfectly boring weather, but it clears after restart. One RRS S/C and one LR3. And there is nothing logged in the computer afterwards... shades of "bug." If it impacts the actual drive, then I'd be worried. |
Have the dealer check the wiring loom on rear of gearbox Chips with everything |
tglick Member Since: 30 Jan 2006 Location: Chicago Posts: 2 ![]() ![]() ![]() |
I have the same problem. However, it occurs everytime I drive the car - usually right after start up, but once in a while it occurs 5 or 10 minutes after. When it first started occuring, it didn't happen everytime I drive, but more like every 5 times I drive. I brought it to my dealership and they couldn't get the problem to reoccur. Ironically, as soon as I pulled away from the dealership it occured again. They said that there is no way to find out what the fault exactly means without hooking the computor up to the vehicle while the fault is present - this is the only way to trace the code that the fault is sending out. They checked the car out from top to bottom and said mechanically there is nothing wrong and it is ok to drive. As soon as I have a free weekend, I am bringing the car back in with the fault on the screen to get to the bottom of this. If anyone else finds out the source of this problem sooner, let me know.
