![]() | Home > Maintenance & Modifications > Fitting Front Mudflaps ... quick question |
ayates Member Since: 08 Jun 2007 Location: Houston Texas Posts: 369 ![]() ![]() ![]() |
I was thinking of fitting a set of front flaps this weekend and before I go ahead I found the installation guide online, looks quite straight forward. However, on looking at the front wheel arch were the flaps would go I can see a rubber strip which I think is the part that need shortened 15mm, is this correct anyone ? Also is there meant to be a metalic centre running through the rubber strip as I can see this on the drivers side ?
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
That sounds about right, although the rubber strip around the wheel arch needs to be cut from just below the top edge of where the flap will sit, all the way down to the plastic trim where the strip ends. That's quite a bit more than a 15 mm section, I think. A strong pair of shears, metal snips or wire cutters will quickly cut through the metal "skeleton" of that rubber trim. I bet you can do both sides in less than 30 minutes. |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Just front ones? .... will that look odd... ![]() |
The rear ones were fitted when I bought the car, but been noticing that without the front fitted I get a a tonne of dirt fly up the sides of the doors. Not to bothered about this but just a pain after its just washed. Plus I think they look good |
Bought them at lunchtime and popped home to install them and umbertob you were of course correct, it took all of about 20mins to fit, really simple doh !
