Home > General > Handheld GPS reception issue
949BFN
South Africa 2007 Range Rover Sport Supercharged Chawton White
Anyone else experience reception problems with handheld GPS's in their RRS? I have a Garmin Zumo 500 fixed to the windshield with the suction mount. The Zumo often gives up with an “Are you indoors” error. Holding it outside the vehicle, almost always result in instantaneous satellite lock on. I do not have the same issue in my other vehicles. (Prado / Audi A8) I've read somewhere that some vehicles (Renault if memory serves me right) have some or other coating in their windshields often causing GPS reception issues and I was wondering if the RR has the same kind of windshield?
Post #122404 Mon Jul 02 2007 5:38pm
It might have something to do with the heated front windscreen element. 2005 Zambezi TDV6 - Gone but not forgotten
Post #122410 Mon Jul 02 2007 5:50pm
Cliff H
Do they have heated screens in South Africa?
Post #122423 Mon Jul 02 2007 6:08pm
Good point.
Do you have heated front screens in SA? 2005 Zambezi TDV6 - Gone but not forgotten
Post #122425 Mon Jul 02 2007 6:09pm
949BFN
I doubt it. I suppose it’s one of those things one would know if one have it? Sorry for sounding stupid and being ill-informed.[/url]
Post #122431 Mon Jul 02 2007 6:19pm
Cliff H
You would have a button on the dash and lots of very small lines in your screen.
Post #122432 Mon Jul 02 2007 6:21pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Some solar reflective glass acts as a good insulator for radio waves, maybe that is the type of glass used in SA?
Post #122434 Mon Jul 02 2007 6:23pm
ayates
United States 2007 Range Rover Sport Supercharged Buckingham Blue
Im sure they do..... We have heated seats all round plus windscreen and this is Texas (Hot & Humid 90% of the time, 76F today so its "cold" and its raining).... think is just Std kit on any RRSsc. Now what I need is A/C for the seats Smile
Post #122437 Mon Jul 02 2007 6:25pm
949BFN
Checked the manual to see what the button looks like. We don't have it in RSA. (I suppose LR had to leave something out - just about all options are standard on the RR's coming to RSA, apart from heated seats (and windshields Smile )
Post #122440 Mon Jul 02 2007 6:33pm
Cliff H
Check your screen though as the elements may be standard even if they are not connected.
Post #122442 Mon Jul 02 2007 6:38pm
Endjin
Scotland
Could the problem be that because the Zumo is specificaly designed for use on a Motorbike (effectively outside), rather than cars, that the arial isn't up to being enclosed in a car. The car acts like a Faraday Cage and if the windsheild has reflective coating (often contains metals), too keep heat out, then the effect is even greater. This is the same reason that devices like mobiles don't always work well in certain buildings where the metal girder construction again acts like a Faraday Cage blocking the signals. - Most Garmin units for cars have an optional external arial available but I don't think there is one for the Zumo.
I know, --- I'm a NURD! Whistle Confused 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #122451 Mon Jul 02 2007 7:13pm
949BFN
I don't think the Zumo's design is at fault, since it works well in my Audi A8 and Toyota Prado. I suppose the RR windscreen is to blame then. The Zumo will take an external remote antenna, but that will obviously mean an extra cable lying around in the cockpit, which I suppose we all hate.
Post #122458 Mon Jul 02 2007 7:33pm
DarrenG
Older GPS Receivers were often affected by athermic windscreen coatings or heated windscreens but the Zumo has a SiRFStarIII chipset which should not suffer such issues.
Can you pull up the GPS Signal Page and tell me how many satellites are reported in the RRS, it certainly sounds like a reception problem but it shouldn't be happening? Darren Griffin
Editor
PocketGPSWorld.Com
Post #122698 Tue Jul 03 2007 8:25am
949BFN
Unfortunately the Zumo does not have a GPS Signal page. The Zumo must be just about the only Garmin without such a page. Sad
Post #122732 Tue Jul 03 2007 4:52pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Surely if the problem is poor signal then it won´t matter what chipset is being used it will have no signal from tzhe satellites to process non??? Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #123129 Wed Jul 04 2007 9:30pm
