![]() | Home > For Sale & Wanted > Tasmod sill plates on Ebay |
tasmod Member Since: 07 Aug 2005 Location: NE Lincs Posts: 396 ![]() ![]() ![]() |
Evolved Member Since: 12 Mar 2007 Location: Caribbean Posts: 35 ![]() |
got your sill plates yesterday...
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Just ordered a set of your Sill Plates on Ebay |
Outstanding - Thanks ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Tasmod,
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Just ordered mine |
You'll Love them flydive. Fitted mine today and they fit really well and look the biz!! Also Tasmod has taken great care to pack them so that they are well protected in shipping. Top Man ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
jampoTT Member Since: 12 Feb 2007 Location: Hatfield Posts: 77 ![]() ![]() |
Are they easy for a complete spazz to fit?
Yep Agree with Tim, They are very easy to fit. The only advice I would give is that you need to make sure you line them up properly before contacting the Sill Surface - Although I'm sure they will come off again it's better to get it right first time. The contacts are (necessarily) very sticky. Hold them at the sides of the plates and fit them 1st without removing the paper that covers the sticky foam then position the rear of the plate under the lip at the back (nearest the inside of the car) of the sill and let the front (curved) edge of the Sill plate drop down over the edge of the sill. This will give you a feel of how it should fit. Once you have done this remove the backing paper and go for it for real. remember to put the rear of the sill plate in 1st and before letting it fall in to place try and make sure the curve is lined up with the edge so it doesnt need to be pushed back or moved forward as this can be a bit difficult due to the grippiness of the adhesive foam. I know it sounds a bit fiddily but it's actually a doddle and if I can do it anyone can! - Cause I really can be a complete Numpty at the best of times ![]() ![]() Good Luck ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Can't wait to get them.... |
Thanks Tasmod, well let's hope for the best. |
