![]() | Home > Technical > KNOCKING NOISE COMING FROM FRONT END |
Smiffy Member Since: 24 Dec 2006 Location: Northamptonshire Posts: 8 ![]() ![]() ![]() |
Hi everyone. I too have the now infamous 'knocking' noise on my 07 model HSE. My local dealer (Hartwell Northampton) have tried hard to fix it, but have been unsuccesful to date. They also tell me that they have several other customers with the same issue. They are adament that replacing the bushes (as advised by VOR) will not solve the problem, and the latest software releases have superceded the patch he mentions too. If you remove the fuse for the ARC system, the noise stops - but obvioulsy the ARC doesn't function!
frizz Member Since: 07 Jun 2007 Location: ashford kent Posts: 28 ![]() ![]() ![]() |
Hi Smiffy.
Possibly so. The first thing I noticed when the fuse had been pulled was that the slight clonk from the steering that you describe (when you turn the wheel from one side to the other at low speed) had gone. |
gables Member Since: 19 Dec 2005 Location: Cork Posts: 12 ![]() ![]() ![]() |
Have had the anti-roll bushings replaced twice! After about a month the knocking returns. Service manager at my local dealership admits that Land Rover do have a problem with RRS and not with FFRR. Land Rover are aware of the problem in UK and as usual are slow to rectify same. Another problem that has compounded my problem is my left front wheel has become unbalanced probably after hitting a pot hole and needs to be straightened by a specialist wheel aligner. This apparantely is adding to the annoying knocking noise especially at about 30-40 mph on uneven surfaces. Wheel costs about €100 to be fixed and is a common problem with alloys on crappy roads. |
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
Hi all I'm back!
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Nice to see you back Doc
sailorman Member Since: 01 Mar 2007 Location: DUBAI Posts: 38 ![]() ![]() ![]() |
i have the same f |
neild.rae Member Since: 12 May 2007 Location: Aberdeenshire Posts: 15 ![]() ![]() ![]() |
Hydraulic shuttle noise apparently - an inherent part of having Dynamic Stability Control fitted (ie all HSE's!!!). Ive had this problem since new (March 07 RRS TDV8 HSE) and I have been categorically reassured its not a problem (LR Regional Engineer) and that I shouldn't worry (LR Customer Services)!
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 ![]() ![]() ![]() |
mmmm... my RRS was in the workshop for 5 and half weeks for the DR ECU and the knocking. LR Tech advised the to replace the bushes, and both roll bars and other bits.....
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
There are several different threads running on this same ongoing problem. Did they not all ought to be combined under one topic? STRENGTH IN NUMBERS Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Glad to see some of you are managing to get LR technical to look at their car. I my self have been declined this honour. I have been told by LR customer services that if the dealer has followed the tips in the bulletin, (which they have and more), then there is nothing more they are willing to do, (Heaven knows which PR school they attended). I do find this refusal bit strange as they have never test driven my car. As Doc says, there may be two problems here.
Hi Frizz I was intreagued with your thread so I tried it out at the weekend. Went and tried the new X5 Diesel. Nice powerfull smooth engine, and guess what - their stability control DOES NOT KNOCK. Yow were spot on though, they drove mine, obviously being suspicious that I wanted to change to a different brand on such a new car, and guess what - they wont take it with that awfull slight but annoying knocking noise. Surely that makes it un-saleable merchandise. You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
So where is everyone going from here? There must be quite a few thousand S/C's and 2007 HSE's out there now - all fitted with DR. How long is it going be before this blows up in Land Rover's face BIG TIME. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
dont forget the TDV8's with DR and the |
