Home > General > Issues with L/R dealers on warranty |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Hi all
Tue Jan 31 2006 11:26pm |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 |
Any modification you make is okay as long as it doesn't lead to a warranty defect. If your car is chipped and the compressor goes, you would be covered. If your turbo blew and LR say the chip caused it then it would not. This extends to any extra, so for instance you put 22" rims on and it knackers the suspension you would not be covered. |
Wed Feb 01 2006 8:23am |
Thanks Pelyma do you know if i have the s/c back box fitted if it will affect the car ? RRS TDV6 Gone but still around
Wed Feb 01 2006 9:31am |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
If you get underneath the car you will see that the exhaust is not sectional. The rear box is integral ( which includes tail pipe ) and the the pipework runs complete to the CAT.see below pic of TDv6 exhaust What I have seen is that some members have got Exhaust companies to cut the tailpipe off and join/weld a new chrome pipe in its place. I can also confirm that JE Engineering are looking at a replacement exhaust for the TDv6 model that resembles the S/C'd - but the chrome tip has a discreet exit directing the emitted gases towards the ground so that your car remains clean from carbon deposits. I am having a new JE exhaust for my supercharged ( large OVALS ) - will post pics as soon as done. " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Wed Feb 01 2006 10:39am |
As from pic above I now see the firm in Nuneaton ( my home town ) are also selling a S/C exhaust system which they say you can fit on a TDV6
Wed Feb 01 2006 11:17am |
Who knows, depends how much is at stake I guess and how good your knowledge is at proving the failure was not down to the modification. Could a non standard exhaust system put heat in the wrong place and affect the wiring, I don't know but that could be an avenue Ford take! |
Wed Feb 01 2006 12:36pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 |
When you look at those two pics, you can see there is no difference in exhausts between the TDV6 and the V8 SC, other than the SC comes in Stainless Steel.
Wed Feb 01 2006 3:21pm |
Aren't the differences going to be at the manifold end? Er.. I'm no mechanic so if that's a stupid thing to say, I apologise!
Wed Feb 01 2006 3:37pm |
Just been talking to a friend that worked on the L/R production line. He told me that the only difference he could see was the tips and he thinks there are the same size on the S/C and TDV6 so it should just fit on with a spot of welding
Wed Feb 01 2006 4:04pm |
JayMann,
Wed Feb 01 2006 4:13pm |
HI all thank you all for your help it was a big help but i don't think it will work i may just have to buy a set of overfinch tail pipes RRS TDV6 Gone but still around
Thu Feb 02 2006 10:16am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Hi, Can anyone tell me why the Tdv6 has got stumpy downwards facing non aluminium pipes? and what effects the carbon might have on a straight S/S exhaust system?
Thu Feb 02 2006 11:07am |
You'll find most modern diesels have pipes that point down towards the ground - the idea is that the carbon deposits in diesel exhaust don't get thrown out into the air. It'd also make a bit of a mess of the back of your car too...
Thu Feb 02 2006 11:11am |
Hi Shmoogle,
Thu Feb 02 2006 11:23am |
