![]() | Home > Maintenance & Modifications > Easy to swap out interior trim? |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
Not so easy - do a search - plenty of info on this site re door/fascia trim swaps |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
If you do swap them i would be interested in your old ones ![]() -------------------------------- P38 Range Rover Autobiography RRS 2.7 HSE Silver RRS TDV8 HSE silver FFRR Vogue black Disco3 HSE silver RRS 2.7 HSE silver RRS 3.0 HSE BALTI BLUE ______________________________ current vehicles RRS 3.0 L494 Autobiography Audi R8 V10 Spyder AC Cobra Landrover Defender 90 Landrover Defender 110 Suzuki Jimney |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Ah Envoy,
xLusi0n Member Since: 12 Jun 2007 Location: Los Angeles Posts: 92 ![]() |
Do you know how much a set of door and center console trim costs from the dealer? |
So they stopped making 2007s and only have 2008s...which means no more polished lined oak trim...which is what I want. Overfinch, however, has the piano black trim that I like so I would like to get those.
jbrac25 Member Since: 09 Apr 2006 Location: Alta Loma CA Posts: 12 ![]() ![]() |
You dont need to remove the door panel to get your wood off the door. You need to remove th emblem and unscrew the screw thats behind it. The with your palms pull towards the door lock. Its pretty easy to do. I changed all my cherry wood to piano black except I had it painted and polished. Way cheaper then buying a new kit. |
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 ![]() ![]() |
Cool |
For the rear doors, and i forgot this on the front doors as well. You have to remove the screw that holds the handle in. Youll see a small circle cover where u can put a small flat head drvier in to open up. Unscrew that then put your palms against the wood and try to slide it towards the back of the door. That black handle piece slides out with the door. The lock has a wire connected to the handle piece which you can just pull away from the panel. It goes back in easy, hard to explain though without you seeing it. The hockey sticks require more work. You have to pull out the ice box or whatever you have there. SO you need to put that flathead into the gap that separates the box from that console piece. Just pop it up a bit and leave it for a minute. You need to pull of the shifter knob by depressing the button and pulling up hard. Dont stop the pull by bringing it back down, ive heard of people smaking their face lol. Then you need to pull all the trim alongside the radio. Get ready to lose some clips into the abyss of that console. In order to get those trim pieces out you must remove the vinyl panels alongside the upper trim. These come out by pulling towards you. Theres a piece on each side. Those gray pieces then just pull out as well. There will be a screw on top of each hockey stick that gets uncovered when you remove that piece. You can then pull that whole console up that covers the cupholders carefully and unplug each of the button wires.
Right so, I’m cool with the disassembly of the entire centre consol, in order to have the (rather large) trim panel piece out that is essentially the “hockey sticks”. As I’ve had all that out some weeks ago, when I was doing a bit of exploratory surgery to investigate the ease of fitting an iPod to my car.
Sorry man i forgot to say that once you get that console off youll turn it upside down and theres four torq screws holding those pieces to the console. Very easy once you get it off. |
Wow torq screws holding on the wood finishers, that’s a bit over engineered.
No problem Rupert
Anyone know if the procedures the same if you have the 2008 with Leather instead of wood trim? |
