Home > General > Pre-driving
neibergs
Latvia 2008 Range Rover Sport TDV8 HSE Java Black
Pre-driving
Dear all RRS owners please help me a novice car owner in the RRS "chalenge". I already wrote that my car should of been produced on the 5th of June 2007, but now the "Stealer" says that he made a mistake and the date is 15 th of June.
Nonetheless, I wanted to ask you all do you know if I have to drive more slowly the first 2000 miles. I have heard that ( this is my first brand new car) new cars need to be driven the first 2000 miles more slowly not exceeding 2500 rpm.
Is that true? Do I have to pre-drive my new RRS? Or is it the way old cars worked?
Please help me inexperinced new RRS owner Cool
Bow down 08 RRS TDV8, Java Black
Post #114285 Fri Jun 08 2007 3:22pm
Not really - don't go flooring it straight away but normal driving and a little bit of fun shouldn't harm the car. 2005 Zambezi TDV6 - Gone but not forgotten
Post #114290 Fri Jun 08 2007 3:33pm
This has been discussed on here a lot.
General agreement is that new engines are manufactured to much higher tolerances than those of old. The reason for running in new cars of old was that they weren't so the parts needed time to bed in.
As VA says, don't go banzai but you also don't need to stick to 2,500 rpm max either! Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #114311 Fri Jun 08 2007 4:46pm
Tim in Scotland
I think the owner manual recommends that for the first 1000 kms you should not allow the engine to labour to in a high gear at low revs............................ and not to try to hit the rev limiter in low gears! It's a lot easier with an automatic, even one that has a manual side to it as the ECU just won't let you do either of the above. Have fun and be sensible! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #114320 Fri Jun 08 2007 5:29pm
neibergs
Thanks
Thank you all for help. I'll drive "carefully" Laughing 08 RRS TDV8, Java Black
Post #114767 Mon Jun 11 2007 6:35am
