d3matt
We've had our RRS sport for a week now. We purchased the local dealer's demonstrator model which was 7 weeks old and had done 3,000 miles.
So far, I'm generally impressed with the build quality - much better than any other Land Rover product. However, I would have to agree that it probably isn't as good as a £43K German car.
We have a faulty headlamp. One lamp doesn't work, but does occasionally decide to come on for a few seconds. It seems like a loose connection somewhere. However, the xeon lamps are so good, driving with only one headlamp working, is about the same as driving with two conventional headlamps! It will be going back this week for a fix under the warranty.
Ours also has loose trim on the left side of the boot. This is the trim that has the power outlet socket. It could be the retaining clips are broken as the trim isn't sitting home tightly. Maybe this has been removed at some time and something has broken. It doesn't look good when you open the boot.
Also, I'm not very impressed with the way the rear hatch shuts. Both the top section and the whole hatch needs quite a hard slam to shut it properly and then it feels like it is shutting on badly adjusted catches. However, another car I have tried is the same. I doesn't feel like the rear hatch is shutting on rubber seals to dampen the shock. It feels crude and cheap. It also seems to be putting too much stress on the two hatches which may cause problems in the future. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Sat Jul 23 2005 9:29pm |
