Home > Technical > Quick Phone Related Question |
wsy679 Member Since: 18 Jan 2006 Location: Bucks Posts: 50 |
I use the Bluetooth all the time.
Wed Jan 25 2006 4:32pm |
rweintra Member Since: 30 Jun 2005 Location: New York Posts: 70 |
Funny, I tried that too, and it didn't work. Its not a catastrophe because I can do the dialing by voice, but lets say the winodw is open, or the passenger wants to dial, it just won't work. I don't get it. |
Wed Jan 25 2006 4:39pm |
djsaad1 Member Since: 10 Aug 2005 Location: Texas Posts: 254 |
i press the green button from the steering wheel then dial a number then press the green button again. Works every time, i would test to see if the problems you are having work with someone elses phone. That way you can tell if something is wrong with your pti system or just your phone.
Wed Jan 25 2006 5:05pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
rweintra, when you first press the phone button on the center console or pull the green answer paddle on the steering wheel, the LCD should display "Bluetooth". You should then be able to dial the number with the radio keypad, pull the green paddle again and get connected. I do it all the time and it works well with my V710. Do you get the Bluetooth message as well? Maybe the one time you tried it with your wife the phone was not linked for some reason (on rare occasions my phone will not pair automatically when I get in the car and I have to do so manually from the handset.) |
Thu Jan 26 2006 8:41pm |
I get the Bluetooth and as I said above, it works fine. If I start with the green paddle, enter the number, then use the green paddle again, its fine.
Fri Jan 27 2006 4:50pm |
As far as I can tell, green answer paddle on the steering wheel and phone button on the radio console do pretty much the same thing. I find the paddle easier to reach and use that method most of the time. However, I just tried this morning to use the phone button instead (press, dial number, press again to send), and it works the same. If dialing out works with the paddle but not with the button, I don't think the problem is with your phone. |
Fri Jan 27 2006 5:15pm |
