Home > Technical > Phone problem
gables
Ireland 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Phone problem
Can anyone help? Use my phone a lot and problem I have is that when I am on a call and another call is incoming and I take the second call without cancelling my initial call the system seems to 'hang' with the audio muted. It will only reset when I stop engine for 3 minutes or so. The telephone number stays on display and will not disappear. Why so?
Post #11118 Mon Jan 23 2006 2:18pm
Hi Gables
Are you using a cradle or via Bluetooth ?
Post #11119 Mon Jan 23 2006 2:21pm
MDP wrote:
Hi Gables
And is it an approved phone? 2005 Zambezi TDV6 - Gone but not forgotten
Post #11120 Mon Jan 23 2006 2:27pm
gables
Phone problem
Using bluetooth through PTI system with Motorola L6
Post #11121 Mon Jan 23 2006 2:30pm
rweintra
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
I sometimes have the exact same problem. I can't get the number to go off the screen and the phone call stays active. The "hang-up" buttons won't work. It takes about 3 minutes.
Post #11122 Mon Jan 23 2006 2:50pm
Hi Gables,
you may want to check this list out of approved phones by LR
http://www.landrover.com/assets/gb/en/Vehi...edures.pdf
The sport is very sensative/software-specific when it comes to phones
Post #11126 Mon Jan 23 2006 3:26pm
rweintra
FYI, my phone is on there, and it still happens.
Post #11137 Mon Jan 23 2006 3:53pm
but have you checked the version of software your phone is operating on ?
Post #11154 Mon Jan 23 2006 4:08pm
rweintra
Yup. Same software. And it happens with Bluetooth and with the cradle. Not all the time. Maybe every ten calls, it happens once.
Post #11157 Mon Jan 23 2006 4:12pm
corrupted software then - ?
Post #11165 Mon Jan 23 2006 4:29pm
corrupted system! Crying or Very sad 2005 Zambezi TDV6 - Gone but not forgotten
Post #11168 Mon Jan 23 2006 4:31pm
Or maybe worth just upgrading the s/w? You never know what little quirks are ironed out in later releases.
Post #11169 Mon Jan 23 2006 4:32pm
rweintra
I put the older software in as the newer software was worse. In reality, they are basically the same. I think what we are proving here is that it is the RRS software.
Post #11174 Mon Jan 23 2006 4:50pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I use my phone on bluetooth without a cradle. Works pretty well most of the time but the bluetooth occassionally loses contact with the phone (or never finds it in the first place). Is there a quick way to get the vehicle to look for the phone (or visa versa) without going through the phone's menu (nokia 6310i) ?
Also has anyone noticed that if the phone isn't "connected" but you flick the green phone button on the steering wheel, that switches the radio on ?
Post #11228 Mon Jan 23 2006 10:29pm
This is also what happens if you hit the phone button on the radio fascia too. It's a bit annoying that they've cut that corner in the electrics - shame the PTI circuit can't activate the speakers independently of the radio.
Post #11257 Tue Jan 24 2006 11:35am
