Home > General > PETROL IN THE DIESEL!
PAULTDV8
OK , dont ask guys , i have filled an empty tank full of diesel , i can get it fixed by landy want 6500 to do it , no bull!
Any advice? surely it would not be this much?
Paul
PS , i was filled then ran for under a mile
Post #111032 Fri May 25 2007 11:43am
mlines
Is it petrol in a Diesel car or Diesel in a petrol car?
Basically Landrover strip and replace everything as injectors, seals, oxygen sensors etc. all on the assumption that everything has/will fail.
If you can find someone willing to drain the system you could then run the correct fuel through and see if it works.
I suspect some of the LandRover costs are bluff anyway - remember that one of the LandRover "advantages" is that their vehicles are designed to run on the crappiest fuel available in remote areas of the world, and the tuning people take advantage of this as engines are supplied in a lower state of tune for this very reason.
The yanks run their military landrovers on Aviation Fuel. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #111033 Fri May 25 2007 11:53am
rrsjo
Diesel in a petrol engine - probably not too serious - drain the tank, change the filter and fill with petrol.
Petrol in a diesel engine - catastrophe! Maybe you could claim off your insurance. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #111034 Fri May 25 2007 12:18pm
mlines
And was it a BP Petrol Station.
I understand BP have paid out a couple of claims for people mistaking Ultimate Diesel and Ultimate Petrol - as the branding is too similar. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #111035 Fri May 25 2007 12:26pm
PAULTDV8
Thanks guys , appreciate this , even if it was 6.5k , ok i'd go on the insurance but hell , its got to be crap!
Currently on its way to an indi
Paul
Post #111036 Fri May 25 2007 12:26pm
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Oh dear P
That is bad news. Sorry to hear it.
A friend of my sister has done it last week on a BMW 3 series Diesel 06 model, and it cost £5500 so your not far off.
The problem is because of the high pressure it runs at, (1500 Bar) the tolerences are so tight you can't bodge it.
If there is a swirl pot in the tank you have to change it to be sure. You can't trust the high pressure pump after because of the warranty. There are no nozzles available for the injectors to clean them so these have to be re-newed at a price of £500-£800 each.
It is a more expensive job than you would guess.
Best of luck with it. You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #111039 Fri May 25 2007 12:44pm
Ian.Richardson
Dont RRS's have some kind a gadget that prevent petrol from being put in a diesel.
When i say gadget it may be as simple as the size of the hole.
Has anybody tested it, I know I wont be. Hopefully.
Post #111068 Fri May 25 2007 5:03pm
Vankerman
2006 Range Rover Sport TDV8 Tangiers Orange
O.K. time to cut the crap!
I am a veteran at this stupidity! Petrol in a diesel is simple to overcome.
If you drove it a matter of yards you will have enough diesel in the fuel line and injectors not to worry as long as you stopped.
Simple to overcome. get some jerry cans, take the fuel inlet hose off the injectors, turn on ignition and fuel pump will empty the tank into said recepticle. A few can normally required for this. They get pi55ed off if you do it on the forecort but Hey Ho!
Refill with diesel and jobs a GOODEN. No crap from me I ve done it twice. Once in an escort van drove it about a mile trailing white smoke............... and once in a Freelander tdv whatever thet are! Laughing
It is not a catastrophe as some would have you believe. The total cost on both occasions for me was a tank of bloody diesel. My mate did it inhis Disco 3, followed my lead and also had no problems at all.
Honest, dont panic geezah!
Post #111077 Fri May 25 2007 6:15pm
The doc
AGREED!
I've helped a few people out now who have done this.
1. Go buy some fuel pipe and an electric fuel pump from the local motor factors
2. Open the bonnet and find the fuel line coming from the rear
3. Break into this fuel line at a suitable point AFTER the fuel filter.
4. Attach your fuel pump and suck the fuel through until empty and dispose of properly.
5. Put a gallon of Diesel in the tank
6. Start the pump again.
7. Once it’s filtered through reconnect the fuel pipes and crank that baby.
8. Look on in horror as it runs like a bag of spanners and smokes like a chimney
9. Look on in happiness as it all quietens down and the smoking stops
10. Keep your fingers crossed
11. Go fill up with D I E S E L
I've done this with normal diesels and high pressure systems and have never had one fail EVER Thumbs Up
GOOD LUCK
BTW. The FFRR has a sytem called PETROL FUEL GUARD that stops you doing this - if you insert a PETROL nozzle it seals of the fuel tank. In the boot you have a yellow stick to re-set the system - NOW why don't they fit that on all Diesels?
Post #111143 Sat May 26 2007 8:31am
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
Like Doc i to have helped many people out in this situation, no real worries
the last one was years ago and it was a couple of girlie's in a Mini we soon sorted them out Twisted Evil , we just abandoned the car in the petrol station got them in to the back of my car and went for dinner.
Dropped them back to there car the next day and towed it to the scrap yard, sorted Whistle
But it was the other way around diesel into petrol, and the car was fit for the scrap yard Rolling Eyes some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #111152 Sat May 26 2007 9:24am
aljo
Rolling with laughter Rolling with laughter saved a few bob there then Thumbs Up
Post #111153 Sat May 26 2007 9:27am
Josh
Dosen't the TDV8 have the same device fitted as the FFRR TDV8 has to stop this happening. I think its on the MY08 spec but I could be wrong. TDV6 - gone
TDV8 - gone
Post #111177 Sat May 26 2007 11:17am
Lateral5
Australia
saw one in my stealers a while back with the engine pulled down....the missus had put petrol in the diesel. $9000, but apparently claimable on insurance Thumbs Up
keep the car, get rid of the missus! RRS TDV6 Bluetooth, VR, Roof
Post #111250 Sun May 27 2007 8:25am
Lateral5 wrote:
saw one in my stealer's a while back with the engine pulled down....the missus had put petrol in the diesel. $9000, but apparently claimable on insurance Thumbs Up
But then who's gonna cook and clean for ya RRS TDV6 Gone but still around
Post #111252 Sun May 27 2007 8:41am
Lateral5
Australia
Good point....but there's always take away for food and
to clean..... RRS TDV6 Bluetooth, VR, Roof
Post #111286 Sun May 27 2007 10:28am
