![]() | Home > Maintenance & Modifications > Chipping |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 ![]() ![]() ![]() |
Sounds good Biggles, I was going to have this done to my D3 but when i started having problems with software and ecu issue, I chickened out.
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
Will do Neil,
BN Member Since: 10 Jul 2005 Location: Northamptonshire Posts: 58 ![]() ![]() |
Since this, I have spoken to Chris at Turbochip at length and details are becoming clearer. The mapping TC do is good if it leaves the low ratio alone. The difference is that I use the D3 for a work horse and off road use, plus towing. But I also average 120,000 miles per year/per vehicle which costs me around �18000 per veh/p/year for fuel, so I have to get it right first time. The good thing is that if it does not work, Chris can reset the mapping back to original.
Cambs Farmer Member Since: 04 Jun 2005 Location: Cambs UK Posts: 10 ![]() ![]() |
For what its worth..........my experience with engines that have either been turned up (properly done using a dynomometer <sp?> to check hp) or chipped, is that it often results in either a blown head gasket (had several |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 ![]() ![]() |
Hello
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
The only downside of my RRS TDV6 is that it is underpowered and drinks the fuel a bit too much for a modern diesel. I've always been a little sceptical of cipping etc. My main reason is that if you can get so much improvement after 7 days of work, why hasn't the manufacturer done the same?
Before I go any further, I am not in league with turbochips in any way what so ever.
The conversion takes 2-3 hours.
Dastek Member Since: 17 Aug 2005 Location: Fife Posts: 7 ![]() ![]() |
Hi All, |
Gerry
Hi all
Going really well, Very little smoke over standard and excellent acceleration.
Hi Turbochip,
Sounds like the chipping war has started,
