Home > Europe > STEERING RACK FAILURE -v- 22" WHEELS |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Welcome on board and sorry to hear about your issue!
Sun May 13 2007 6:52pm |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 |
Is the RRS not meant to be one of the most capable off road vehicles in the world?
Sun May 13 2007 7:02pm |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Put the standard wheels back on and try another garage
Sun May 13 2007 10:13pm |
It seems odd that a TDv8 has this problem because those of us that remember back to the very early days of RRS will recall that LR upgraded the steering rack on cars running 19" wheels to the same one as S/C due to a spate of failures when folks put 20" Stormers onto their TDv6's. I cannot imagine that you have an "old Style" rack on such a recent car but it might be worth asking the dealer if yours is the uprated rack that was fitted to some cars as a warranty item 2 years ago. My own RRS still has the original rack as far as I know, I have never fitted bigger wheels to it. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon May 14 2007 7:08am |
You're right Tim. Surely the TDV8 is fitted with the upgraded steering rack you mentioned, if not a later one! Malaysia Boleh!
Mon May 14 2007 7:17am |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
There is no way that the 22" wheels have caused the rack to fail. This vehicle is designed to cope with steering forces off-road, such as against the side of gullys, against the side of rocks and turning in sand and mud! Even steering with one front wheel not touching the ground.
Mon May 14 2007 7:49am |
From his location I don't think Neil has ANY choice of dealer, there is one dealer at Perth (Stratsones), one at Aberdeen (Town and Country) and 1 dealer (Macrae and Dick) covered the rest of the north of Scotland from Inverness. Perth and Inverness are both long way from Aberdeen. (2hours drive approx) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon May 14 2007 6:25pm |
I have a non-Dynamic Pack car fitted with 20" Stormers.
Tue May 15 2007 10:22pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Neil, I know this post was a while ago but I have just joined and thought it worth replying to you.
Fri Jun 22 2007 3:56pm |
bigfoot Member Since: 05 Oct 2008 Location: Northumberland Posts: 1 |
Interesting, my RR sport TDV8 2008 MOD with 3,600 miles developed a clunking noise on the near side and a knock which can be felt through the steering wheel if the car is turned sharply to either side. The car is fitted with the standard Stormer wheels and I have recently had the car back into the dealers who have told me the problem is with the ARC and so far there is no fix for the fault. One of the technicians who road tested the car with me said that particular dealership had had around 5 other reports of the same problem and apparently only TDV8's have the problem.
Sun Oct 05 2008 9:04pm |
Bigfoot - there is a big thread in the Technical sections of the forums about you problem - here
Sun Oct 05 2008 9:24pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
The S/C (now HSE / Dynamic Pack and S/C) spec rack is damped but the ball joints in it etc are VERY similar sized to the non-damped, I´d be very surprised if it is any stronger. The issue with 20" wheels was one of harmonic frequencies leading to a steering shimmy rather than outright failure of the rack. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Mon Oct 06 2008 9:53pm |
