Home > Technical > Sat Nav Screen Pulsates
tlw
United States
I've noticed that my Sat Nav screen sometimes pulsates - that is to say that it dims and then brightens. It does this whether the lights are on or off and does not seem to have anything to do with the timing of the headlights turning on and/or off. It is somewhat intermittment. Anyone else experienced this? Thanks. tlw '06 RRS HSE Chawton White/Alpaca Lux/PTI/Sirius
'04 Ford F250 Super Duty
'01 Jeep Wrangler
'05 John Deere 5320
Post #10791 Thu Jan 19 2006 4:33pm
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
Mine has done this once or twice. It often is very bright at night or goes very dim during the day, but generaly it is okay most of the time. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #10793 Thu Jan 19 2006 4:44pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Mine has too, only about 3 times in all. I decided it was not worth complaining about unless the screen went pop completely. I guessed it was because of slight voltage drop or something. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #10795 Thu Jan 19 2006 4:46pm
kam100
I noticed this, basically its dependant on your vehicle speed i think.
If you have the menu screen on with the destination entry/postcode entry thingy, as you know when you speed up, you can't select to add the address, so the screen dims slightly, when you slow down it goes brighter as it will now allow you to input stuff..
Thats what i reckon anyway, anyone else have anr theories? As mine seems to go dim then bright etc all the time too...
Post #10869 Thu Jan 19 2006 11:11pm
grommet
United States
Note, there is a light sensor that controls the brightness somewhat if I remember correctly.
It's never irritated me personally.
Post #10872 Thu Jan 19 2006 11:34pm
