Home > Maintenance & Modifications > Rubbing strips fitting instructrion
Jimmy_75000
I have ordered the rubbing strips and looking to install them this week-end and need your help... As always, the instructions are very clear!!!
On the instruction that you can see on the http://www.ownerinfo.landrover.com , page 4 of 5, drawing n3, what the hell does 10mm means??? Is that 10mm from the bottom of the door??? That seems way to low! Or do they mean 10 cm??
Any help? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #106875 Thu May 03 2007 12:29pm
Tim in Scotland
It looks like it is 10mm below the crease in the lower door panel 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #106880 Thu May 03 2007 12:55pm
Jimmy_75000
So I guess the top of the strip should be 10mm (1cm) below the lower door panel....Will work on it this week end.
thanks Range Rover Vogue ‘17 TDV6
Post #106901 Thu May 03 2007 2:37pm
