Home > General > FLAT TYRE
FLAT TYRE
Would you Adam & eve it - went out to car this morning and the rear offside was completey flat Crying or Very sad Having removed it & put spare on ( quite simple ) it appears to be down to a large piece of metal that has penetrated the tyre through the centre of the tyre/tread. ( pics later ) I hope to get this repaired.
Post #10498 Mon Jan 16 2006 11:41am
Jesus... we need to invent a competition for World's Unluckiest RRS Owner so that you can win it! Laughing
Post #10500 Mon Jan 16 2006 11:43am
Re: FLAT TYRE
A repair on the tyre is unlikely - you should get a new tyre. 2005 Zambezi TDV6 - Gone but not forgotten
Post #10502 Mon Jan 16 2006 11:44am
byron
Greece 2006 Range Rover Sport Supercharged Bonatti Grey
A similar incident occured on my car a couple of months ago. Despite the looks of the damage,it can be repaired. Apparently a square shaped patch is placed on the interior of the tyre and pressed against it under heat. The square patch melts and fills the gap. The tyre guy reassured it me its perfectly safe, however, I ll probably change the tyres sooner than normal, just to be on the safe side.
Best of luck RRS S/C,Bonatti Grey,Ebony Interior,Lined Oak Finish, Rear Lock Dif, DVD,Sunroof,ACC
Post #10506 Mon Jan 16 2006 12:02pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
That IS bad luck, and I thought I was having the poor trot of luck.
There's nothing more galling than having to replace a tyre that is almost new, how annoying. With the amount of crap on our roads though it's bound to happen at some time, especially if you frequent commercial property areas. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #10535 Mon Jan 16 2006 3:38pm
Spoke to dealer - he came up with best price 275/40/20 continental sport contact ( straight replacement ) £199 fitted. So will get this done tomorrow & then I will look to get the other repaired in my own time ( if its repairable )
Post #10546 Mon Jan 16 2006 4:19pm
RRUK
What other? L319 D4 HSE
1982 Series 3 SWB
Post #10565 Mon Jan 16 2006 5:24pm
KevinJM
Yugoslavia 2008 Range Rover Sport TDV8 HSE Java Black
Byron's solution is fine, someone stabbed my tyres (near side front and rear) about 2 months ago; I had 3 wounds up front, 2 behind. The tyres were repaired (patched if you will) from inside and I've had ne'er a problem since - which is more than I can say for the little b@&"£?^ who did it if I ever find out who it was! I've been driving in low temperatures for the past month (avge -6 during the day) and still have no bad experiences with the repair job RRS TDV6 (gone)
RRS TDV8 HSE(gone, burned out)
ML 320 CDI Airmatic
Post #10600 Mon Jan 16 2006 9:40pm
Bobby
RRUK wrote:
What other?
The damaged one? Surprised Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #10616 Mon Jan 16 2006 11:03pm
POXY SPARE
So here are the long awaited pics.
You will note that even though I run a Supercharged the spare is only a 19" and the rubber as follows 255/50/R19 you will notice from the photo that there is a nice big yellow sticker informing the driver not to exceed 50mph Twisted Evil
What bl**dy use is this on a Supercharged? Lets say you are on holiday abroad - say the south of France - 1000 miles to get home - you cannot get your hands on a replacement tyre ( full size 275/40/20 ) its difficult enough getting hold of one here. You are then stuck with travelling all the way home at a limited 50mph
Sorry for the LARGE format/size of the last 2 photos but great for detail.
All photos taken with Canon EOS 300D Crying or Very sad[/img]
Post #10630 Tue Jan 17 2006 9:57am
Nice look! Very Happy Very Happy 2005 Zambezi TDV6 - Gone but not forgotten
Post #10631 Tue Jan 17 2006 10:21am
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
I've just got a pucture on my van tyre repaired. The local tyre shop wouldn't and would only supply a new tyre - which I did. I then got the damaged tyre sent away through someone in the family who is in the trade. It has come back repaired and only cost £20! The damage was a screw in the tread, but near the side - which the tyre shop said was definately unrepairable. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #10632 Tue Jan 17 2006 11:17am
Hi Matt
Having spoken to my dealer re this - he quite simply said - a repaired tyre on a 2.5ton car that can do 140mph - so I am buying a new one to put on later today ( from the dealer he was the cheapest @ £199 ) and I will then get the duff tyre repaired to keep as an emergency/spare - because thet are not the easiest thing to get hold of.
On reflection £199 = peace of mind
Post #10633 Tue Jan 17 2006 11:31am
They've definitely made sure you're not going to leave your spare on for much longer than you need to, haven't they? Wink £199 was a good price for a dealer to be quoting for the tyre though... like you say, they're not the most common size.
Post #10634 Tue Jan 17 2006 11:31am
Here's an idea! Buy a set of wheels and tyres on ebay. Keep the tyres and resell the wheels. You could end up with the tyres at a very reduced rate! 2005 Zambezi TDV6 - Gone but not forgotten
Post #10635 Tue Jan 17 2006 11:42am
