Home > Off Topic > Sailing expressions
Page 1 of 4 1234>
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Sailing expressions
You think tall ship spotting is sad - you should try our local game of spotting "sailing expressions". Meaning English language phases that are in everyday (or at least common) useage that originated on board sailing ships. There are squillions of them, and it proves what big influence sailing and sailors had in GB.
A few examples are (which I would be happy to explain the origin if not already obvious):
Batten down the hatches
Any port in a storm
Given a fair wind
Go overboard
Go by the board
Catch my drift
No room to swing a cat
The bitter end
A slush fund
Skimming off the top
A square meal
Kick the bucket
Money for old rope
Show someone the ropes
Sailing too close to the wind
Under the weather
Keep a weather eye
In the offing
Have a set back
A load of bilge
Between the devil and the deep blue sea
Toe the line
Welcome on board
Hoisted by his own petard
Pin your colours to the mast
A loose cannon
Son of a gun
All hands on deck
Ship shape and Bristol fashion
A1 condition
Float (as in float a company on the stock exchange)
Cuts no ice
Go below decks
On the rocks
Cut and run
Break new ground
Tacky
Four sheets to the wind
Shiver me timbers
Splice the main brace
Go down with the ship
Clear the decks
Over a barrel
In the doldrums
Welcome on board
Choc a bloc
Make sail
The cats out of the bag
The cats got his tongue
Dick the cabin boy
Seaman Stains
A waister
Rats from a sinking ship
POSH
Gangway
Copper bottomed
Cold enough to freeze the balls off a brass monkey
Nipper
Shove off
Ships that pass in the night
Scrapping the bottom of the barrel
Miss the boat
Making headway
Swinging the lead
Lifeline
Laid up
All in the same boat
Left high and dry
Hard and fast
Chunder
Flotsam & jetsam
First rate
Under rated
I could go on and on, but would welcome any others ........... RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #105081 Wed Apr 25 2007 8:58pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Thanks for that Smarticus! Yawn MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #105093 Wed Apr 25 2007 10:54pm
pussy
scuttlebutt.
a scuttle is a small rectangular hole cut into the side of a ship for light and ventilation or a way of communicating at times to another deck.
a butt is a receptacle for water.
to stop the crew from drinking a butt each day when it was to last two days and to ration the water they drilled a hole half way up and hung it from the top deck and poured the fresh water up to the hole. Very Happy no regrets!
ONE LIFE LIVE IT.
Post #105099 Thu Apr 26 2007 4:43am
pussy
http://www.bluewatersailing.com/expressions.php
Thumbs Up Very Happy no regrets!
ONE LIFE LIVE IT.
Post #105100 Thu Apr 26 2007 4:53am
Smarticus
Great list Pussy - Bow down but they have overlooked "Dick the Cabin Boy"
You might be able to help with "Shiver me timbers". The origin of that is the subject of some debate, but it has been explained as the sound a wooden ship's hull makes when the hull is moving backwards in the water. In that direction the seams on the wooden hull catch the water and this makes a reasonance that is then magnified by the shape of the hull, creating a "shiver". Any sailor would live in fear of that noise as a hull moving backwards in the water is inherently very unstable (usually as a result of such a big sea that the ship cannot crest a large wave and falls backwards, or having sailed so close to the wind that the sails "set back" and start pushing the ship backwards). Not being a sailor myself I cannot relate to that explanation very well. Does it sound reasonable to you ?
And to any Aussi readers - I am told that Chunder is the expression used for throwing up / vomiting in Aus. The origin is apparently from the sailing ships that took convicts or emigrees to Aus. The berths were bunk beds, often 3 or 4 layers high. Someone in an upper bunk who was suffering from sea sickness would try to warn the people in the lower bunks that they were about to throw up by shouting "watch out under". This would get shortened (given the time available to bark the warning) to "chunder". Any confirmation ?
And finally, "Freeze the balls off a brass monkey". I believe that a brass monkey is a brass plate with 4 holes cut out of it which was used to store cannon balls beside the cannon. Each cannon ball would slot into a hole, which was cut to allow the ball to sit in the hole and not be able to roll out in a heavy sea. The plate was made of brass so there was no risk of a ball rubbing against the metal creating a spark (very dangerous when there was lots of gun powder around). In very very cold weather the brass plate would shrink and the 4 holes would therefore move closer together. If it shrunk far enough the 4 cannon balls would push each other out of the holes and the balls would fall off the brass monkey. Any confirmation ? RRS TDv8 HSE Rimini
Post #105101 Thu Apr 26 2007 6:27am
I always thought that was "Roger the Cabin Boy"?
This was the explanation I'd heard too.... Very Happy
Post #105106 Thu Apr 26 2007 7:42am
pussy
not quite, but very nearly.
http://www.snopes.com/language/stories/brass.htm
Thumbs Up no regrets!
ONE LIFE LIVE IT.
Post #105123 Thu Apr 26 2007 8:21am
Shocked
Misled again!!! Crying or Very sad
Post #105128 Thu Apr 26 2007 8:28am
pussy
re "shiver me timbers"
Timber:
branching outwards from the keel of a ship and bending upward into a vertical direction. constructed of several pieces of wood.
Shiver:
to tremble in the wind as the wind strikes one side of a sail and then another.
possible:
linked to pirates, the shock of a large wave hitting wooden ships broadside. or a ferry to Ireland Shocked Shocked
shiver me timbers first recorded in script 1835. no regrets!
ONE LIFE LIVE IT.
Post #105141 Thu Apr 26 2007 9:14am
Brian Mason
Laughing Laughing Laughing
Plus.., Seamen Staines, Master Bates, and then let's not forget the main man, Captain Pugwash, which also has a sexual connotation!!! Whistle MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #105177 Thu Apr 26 2007 12:46pm
Sounds like your average Friday night out in Essex! Laughing
Post #105180 Thu Apr 26 2007 12:48pm
Brian Mason
That would be a QUIET weekend night out in Essex. Lucky I only work there and dont actually live there! Evil or Very Mad MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #105203 Thu Apr 26 2007 1:21pm
....as you're always at pains to point out. I've seen you going into the Pink Toothbrush on more than one occasion!! Whistle
Post #105204 Thu Apr 26 2007 1:22pm
Brian Mason
In Rayleigh? OMG S.., dont tell me YOU'RE an ex-Essex Boy? I do recall you talking about owning a sooped-up XR3 and cruising at Southend. Or was that cruisin on Clapham Common? Shocked MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #105213 Thu Apr 26 2007 1:32pm
Rolling with laughter Rolling with laughter Rolling with laughter
So it WAS you!! Shocked
Nope, I'm glad to say I have nothing to do with Essex and have only ever crossed the border into Lakeside on a couple of occasions, but since Bluewater opened stopped doing that as soon as was humanely possible. I think the whole place should be Censored napalmed.
Post #105215 Thu Apr 26 2007 1:37pm
Page 1 of 4 1234>
