![]() | Home > General > Park Distance Control |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
They should stay on from start to finish, unless you hit the button. Check and see if the orange light is on? MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs |
EMIRATES_GUY Member Since: 14 Oct 2006 Location: ABU DHABI Posts: 6 ![]() ![]() ![]() |
yeah the same with me ?!!!
Strange? Mine remains "on" all the time unless I cancel by pushing dashboard button. The sensors activate at low speed when reversing or edging forward? No point having to turn it on each you perform tight manoevres.., what a pain! See your stealer! Good Luck fellas. |
Ian.Richardson Member Since: 12 Feb 2007 Location: UK Posts: 101 ![]() ![]() |
I thought they turned off over a ceratin speed and only turn on again automatically when you are in reverse gear. |
Frisco_TX_RRS Member Since: 13 Apr 2007 Location: Frisco, TX Posts: 25 ![]() ![]() ![]() |
My light goes off and does not come on once I'm on the road.
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
The front sensors used to come on all the time at speeds below 10 mph, but there was such a chorus of discontent from early owners tired of those annoying false alarm beeps (a pedestrian at an intersection, a nearby truck, a friggin' fly would often be sufficient to trigger them) that Land Rover basically "crippled" - but of course they say they enhanced...
As Umbertob says, the system should remain "live" at all times and the rear sensors activate when reversing without the need to switch back on. Something doesnt seem right, check with your Dealer! ![]() |
Thanks again guys for the clarification |
Good luck Frisco! |
They are a real pain when you take the car offroad and you have to turn them off if you are getting anywhere near any rocky bits or have to climb highish bumps. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
thanks guys
