![]() | Home > Technical > Reduced Engine Performance Fault |
May or may not reappear after you restart the engine etc.... if it reappears more than a couple of times, a dealer visit is probably pertinent. |
This is a new one... . Malaysia Boleh!
I had this happen a couple of times last year in one trip, the engine went into limphome mode and I posted about it somewhere........................ IRC it was fixed with a replacement sensor and an ECU upgrade. Mine is a TDv6 though 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Invictus Member Since: 12 Jan 2007 Location: Atlanta, Georgia Posts: 30 ![]() ![]() ![]() |
It was a software upgrade. They reset the ECU and away I went.
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Mine required a new sensor and ECU upgrade.., which wiped remap! Sometimes the LR Assist techician can recify with laptop. Switching engine off and back on again normally cancels message and "limp mode." But, as Shmoogle says, if it recurs a dealer visit is required, although dont panic because its unlikely that actual damage is being caused to engine. |
