Home > Tips & Tricks > ACE Filter replacement
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi Kev thanks for vid link have you changed your filter ?
Post #617621 Thu Sep 23 2021 8:58am
knwatkins
Yes, the filter is easily changed too. See the vid I posted previously earlier on in this thread Thumbs Up Kev
Post #617625 Thu Sep 23 2021 11:03am
Iomegas
Cherrz Kev have ordered filter I was just worried about some articles I noticed saying the threads broke up in housing when you removed the plug sometimes. Thumbs Up
Post #617654 Fri Sep 24 2021 8:20am
Supermondo
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hi guys, does anyone know what size socket is required for the filter plug?
Post #617699 Sun Sep 26 2021 9:49am
38mm
Post #617701 Sun Sep 26 2021 10:10am
DirtBuddha
England 2010 Range Rover Sport TDV8 HSE Galway Green
Where do you guys buy the filter and fluid from... LR Dealers (hopefully not at their prices)?
Post #620988 Sun Jan 16 2022 10:52am
knwatkins
Fluid from here: https://www.smithandallan.com/products/tra...over-ace-/
https://www.ebay.co.uk/itm/252649100035
Part number for the filter is RVJ100010. Plenty of places on the web. For example:
https://www.ebay.co.uk/itm/222658622408
https://www.lrseries.com/RVJ100010-FILTER-...EPLACEMENT
https://www.island-4x4.co.uk/valve-block-f...28228.html Kev
Post #620990 Sun Jan 16 2022 11:19am
DirtBuddha
Cheers!
Post #620993 Sun Jan 16 2022 1:25pm
DirtBuddha
So how do people drain/replenish the ACE fluid?
I watched a video on YouTube on doing it on a Disco 2 using a turkey baster, but the reservoir on a 2010 RRS TDV8 is a LOT smaller than on the old Disco 2, and the cap/opening is a much smaller diameter.
What do you use and how do you do it?
Post #621062 Tue Jan 18 2022 11:06am
knwatkins
Drain it out with a little 12v pump. Kev
Post #621063 Tue Jan 18 2022 11:44am
DirtBuddha
How much do you take out at a time though? And won't that introduce air into the system?
The vid I watched suggested being VERY careful not to introduce air into the system, otherwise it needs to be hooked up to a computer for several hours and cycled through all its settings to purge air from the valves and system.
Post #621067 Tue Jan 18 2022 2:08pm
knwatkins
You can change it from below through disconnecting the lines to the ARBs. That could introduce air into the system and is more of a pain to do on the driveway.
I just drain and refill the reservoir in its entirety over the course of a week or so until the fluid is nice and clean. Kev
Post #621088 Tue Jan 18 2022 10:42pm
No mention of having to use a computer in the manual, you bleed it using the same principle of pressure bleeding a brake system, unfortunately you do need one of these special tools 204-591-02 (£400.00 from L/R so no surprise there then) to open the solenoids to allow the fluid through to the bleed screws, unless you could improvise one without to much difficulty just need to energise the solenoids with live feed to open them. As said not sure it would be very easy without a pit or ramp.
Post #621089 Tue Jan 18 2022 11:18pm
Meiang
I empty the reservoir using a syringe and short length of hose and refill it several times running the engine for several minutes inbetween refills (to circulate fluid) at every engine oil change.
I also change the filter every two years.
Post #622323 Tue Mar 01 2022 7:21am
