Home > Tips & Tricks > ACE Filter replacement |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
That is true so don't over tighten the nut.
Wed Jun 09 2021 7:46pm |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
Thanks Kev I’ve got the Torque settings for it so it should all be good lol i hope 🤞 lol |
Wed Jun 09 2021 8:10pm |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 |
There is an O ring on the nut so make sure your new filter comes with that too. |
Thu Jun 10 2021 7:40pm |
Thanks Nilrem appreciate your reply i wire brushed around the housing today and sprayed some penetrating fluid onto it for good measure . |
Thu Jun 10 2021 8:31pm |
Kev
Thu Jun 10 2021 9:09pm |
3 |
Thu Jun 10 2021 9:16pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
Rather than use screwdrivers to lever old filter out, there is actualy a thread in the base of the filter which you can screw a 6mm treaded bolt into to wriggle it out with if you wish. Little easier if you happen to be laid on the floor doing it.
Sat Aug 07 2021 5:45am |
Hi great advice appreciated cheers. |
Sat Aug 07 2021 8:28am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
I bet LR have a special tool for that. Probably available at the cut-price cost of just a single kidney. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Aug 07 2021 11:43am |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
I change my filter every year. It might be a bit of an overkill, but I have never had a problem with the system after 11 years. It is cheap insurance as they are cheap enough. |
Fri Sep 17 2021 3:01pm |
Hi thanks for your comments I take it you haven’t had any problems with the threads of the alloy housing when you put screw the cap back in ? |
Fri Sep 17 2021 5:23pm |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 62 |
has anyone replaced the fluid in the ACE system?
Wed Sep 22 2021 2:11pm |
Yes. The official procedure to drain the fluid is via the fitting on the ARB itself. Mine was rusty so I didn't want to touch it and risk rounding and/or leaks. It's much easier to do multiple drain and refills directly from the reservoir to switch out the black horrible fluid for nice clean stuff. Kev
Wed Sep 22 2021 6:45pm |
Kev
Thu Sep 23 2021 7:08am |
