Home > Tips & Tricks > ACE Filter replacement |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 208 |
Hi Kev thanks for vid link have you changed your filter ? |
Thu Sep 23 2021 8:58am |
Cherrz Kev have ordered filter I was just worried about some articles I noticed saying the threads broke up in housing when you removed the plug sometimes. |
Fri Sep 24 2021 8:20am |
Supermondo Member Since: 08 Aug 2021 Location: Milton Keynes Posts: 1 |
Hi guys, does anyone know what size socket is required for the filter plug? |
Sun Sep 26 2021 9:49am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4876 |
38mm
Sun Sep 26 2021 10:10am |
DirtBuddha Member Since: 12 Jan 2022 Location: West Sussex Posts: 28 |
Where do you guys buy the filter and fluid from... LR Dealers (hopefully not at their prices)? |
Sun Jan 16 2022 10:52am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Fluid from here: https://www.smithandallan.com/products/tra...over-ace-/
Sun Jan 16 2022 11:19am |
Cheers! |
Sun Jan 16 2022 1:25pm |
So how do people drain/replenish the ACE fluid?
Tue Jan 18 2022 11:06am |
Drain it out with a little 12v pump. Kev
Tue Jan 18 2022 11:44am |
How much do you take out at a time though? And won't that introduce air into the system?
Tue Jan 18 2022 2:08pm |
You can change it from below through disconnecting the lines to the ARBs. That could introduce air into the system and is more of a pain to do on the driveway.
Tue Jan 18 2022 10:42pm |
No mention of having to use a computer in the manual, you bleed it using the same principle of pressure bleeding a brake system, unfortunately you do need one of these special tools 204-591-02 (£400.00 from L/R so no surprise there then) to open the solenoids to allow the fluid through to the bleed screws, unless you could improvise one without to much difficulty just need to energise the solenoids with live feed to open them. As said not sure it would be very easy without a pit or ramp.
Tue Jan 18 2022 11:18pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 391 |
I empty the reservoir using a syringe and short length of hose and refill it several times running the engine for several minutes inbetween refills (to circulate fluid) at every engine oil change.
Tue Mar 01 2022 7:21am |
