Home > Technical > Front differential |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4857 |
According to the workshop manual they are the same ratio 3.54:1 provided it comes from a vehicle with the 6 speed transmission (6HP28), the 8 speed ratio is 3.21:1, don't know whether the complete unit is interchangeable between models though, although saying that, some of the part numbers for the complete assembly appear to be the same for both models.
Fri Mar 29 2024 2:06am |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 |
Cheers Col, that’s great 😃 |
Fri Mar 29 2024 8:29am |
finally got the front diff out ...what a PIA the ACE roll bar is ....
Tue Apr 02 2024 5:42pm |
2 RRS Member Since: 04 Sep 2016 Location: Stafford/Telford Posts: 107 |
I'm sure I remember there was a tsb for the diff casings inner surface treatment failing, its kind of a Teflon coating, maybe worth checking? |
Tue Apr 02 2024 5:56pm |
i think mine has that , there are bits of black (like paint flakes), but not much left from what i can see. could the damage be done? |
Tue Apr 02 2024 6:31pm |
