Home > Tips & Tricks > How to replace the front seat base foam
Page 8 of 8 <12345678
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi Col,
They list LR016245 and LR016246 as a seat base element, I'm guessing the first one is for a HSE type seat and perhaps the other for AB's ?
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #633745 Thu Jun 15 2023 11:16am
The foam pad is the same in the a/b don't see any reason the heating element would be different.
Post #633746 Thu Jun 15 2023 11:22am
Jabba
Ah ok, perhaps I needed to order LR016246 instead then ?
I'm in contact with LR Direct who I placed the order with, I'll update on the outcome. Thanks Col
Many thanks
Post #633747 Thu Jun 15 2023 11:25am
Just looked at L/R microcat parts list says LR016245 is for Taurus Leather/PVC what ever that looks like and LR016246 is for Windsor Leather/Alacantra.
Post #633748 Thu Jun 15 2023 11:40am
Jabba
Ah ok, my fault, thanks Col
Many thanks
Post #633749 Thu Jun 15 2023 11:43am
Jabba
That's just typical, the heating element I need, LR016246, is currently out of stock and is on back order Big Cry
Looks like I'll have to fit the new base without the element as I need to use the RRS in a couple of weeks.
Many thanks
Post #633773 Fri Jun 16 2023 12:30pm
Can you not try and gently peel the old one of the foam and use some spray on adhesive to stick it on the new foam, assuming the heater was still working of course, might be worth a try.
Post #633778 Fri Jun 16 2023 10:49pm
Jabba
Hi Col,
Well, being the idiot I am, I cut through the material to remove the rods in the foam. I know, I'm a total idiot.
Many thanks
Post #633779 Fri Jun 16 2023 11:03pm
Lesson learnt there for the future Craig, make sure you have the right part's before you start anything. Rolling with laughter
Post #633780 Fri Jun 16 2023 11:33pm
Jabba
Yes definitely, it's strange, I normally do check, christ I've worked on enough cars over the years, oh well Banging Head
Many thanks
Post #633782 Sat Jun 17 2023 5:42am
Jabba
Right, that's that job done. Picked up the correct element from the dealer at 8 this morning and its all back in. Must admit the new foam does feel alot better.
Thanks for your guidance guys, always appreciated
Many thanks
Post #633879 Thu Jun 22 2023 3:12pm
RRR
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
knwatkins wrote:
Sorry to ressurect an old thread but I just thought I'd let you guys know I replaced my driver's seat base today.
My local main dealer Land Rover parts desk told me that the seat base was on back order and they couldn't get them for 4 to 6 weeks. However, our forum sponsor, Advanced Factors in Southampton were able to order the base direct from Land Rover and get it to me within 3 working days Confused Fantastic service as always, especially with the current 12% discount code Thumbs Up
I reused my existing heated seat element as it separated easily enough from the old base.
If anyone is considering doing this, I recommend it. It's dead easy and doesn't take long to do at all.
Hi knwatkins, appreciate this is a very old post!
I have the same seats in mine, can you recall the part number for the foam base? Was it HGB500050?
Cheers!
Post #639058 Tue Jan 23 2024 2:31pm
No HGB500050 is for pre-facelift and facelift SE's, you need LR021399 for HSE/AB facelift variants or that is what is the one I used.
Post #639071 Tue Jan 23 2024 9:04pm
RRR
Thank you for the reply, much appreciated.
Post #639283 Wed Jan 31 2024 4:29am
