Home > Tips & Tricks > How to replace the front seat base foam |
timmos Member Since: 20 Feb 2017 Location: Burton On Trent Posts: 22 |
nice one... i'll be giving this a go at some point!! |
Mon Jun 19 2017 7:11am |
Begs the question, would it be possible to add extra foam to the side bolster part, maybe slice a piece of off the old foam? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Jun 19 2017 8:01am |
betarr400 Member Since: 28 May 2017 Location: roma Posts: 10 |
Mon Jun 19 2017 3:03pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
Have a look in ebay, there are a few on there |
Mon Oct 09 2017 8:29pm |
really? I've been searching and cave come up with nothing... I've ordered the new foam, just really annoyed what the slits in the base |
Mon Oct 09 2017 8:33pm |
Ah, just realised most of them are for rear seats. There is one front but its tan and £199. Depending on position and size of tear, is it worth trying a diy repair kit? |
Mon Oct 09 2017 8:48pm |
I'm going to give it a go my self, all else fails ill have to take it apart again and send it in somewhere |
Tue Oct 10 2017 9:08am |
eapaul Member Since: 15 Feb 2018 Location: Isle of Wight Posts: 1 |
Thank you for your time writing this thread, its really helpful! |
Thu Feb 15 2018 4:39pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
I decided to replace my foam but had a problem. All the venders check my VIN and tell me that the foam is the same for the 05 to 13 MY. I bought pt no.HGB500050 Which appears to be the 05 to 09 as it’s different to my 12MY. The 2 wires that run across the base are about 2 inches closer together. Can anyone give me a price no. For the face lift seat foam so I can pass it on to a vendor to source. 2012 5.0 SC AB
Mon Apr 23 2018 8:15pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4867 |
I replaced mine on a MY13 A/B and it was Part No. LR021399 for Vin. AA224294 on and it fitted perfectly.
Mon Apr 23 2018 9:53pm |
Thanks Col, used your pt number and did search, that’s the correct one and got one on order. My VIN is
Tue Apr 24 2018 10:18am |
Hi,
Tue Apr 24 2018 12:32pm |
I see, so it looks like there may be some mistakes with the pt number ranges. My foam matches perfectly the type you listed but is 4000 vehicles before that. No wonder all the suppliers keep quoting the wrong number. Mine are original too being marked as Aug 11 and my car was built in Sept 11.
Tue Apr 24 2018 1:58pm |
Pre Facelift cars 05/09 use HGB500050, Facelift variant 10/13 use LR021399 there was another one LR016234 but that has been superseded to 021399 that is it, there are now only the two, one for pre-facelift and one for facelift models.
Tue Apr 24 2018 9:28pm |
