Home > General > Why is the RRS so heavy?
redtarga
2006 Range Rover Sport Supercharged Buckingham Blue
Can someone shed some light on why the RRS is more than 2,500 kg?
Comparative SUV's are around 2,200 kg or less.
Even top of the line, Range Rover is about 100 kg lighter than the RRS, if I am not mistaken.
With the exception of the extra large American SUV's, I did not find too many cars or SUV's heavier than our RRS?
Post #8576 Thu Dec 22 2005 6:53am
RRSportest
Estonia
That's because it is full of great stuff Smile . But seriously you can look in the forum, I remember reading something on this topic before. TDV6 Java Black Alpaca Leather and some extras
Post #8578 Thu Dec 22 2005 8:08am
It aint heavy...................... Very Happy 2005 Zambezi TDV6 - Gone but not forgotten
Post #8580 Thu Dec 22 2005 9:08am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
The primary reason for the RRS weight issue is that is has a double chassis.
Traditional Land Rovers had a ladder frame chassis with live beam axles until the P38 RR, then when they introduced the L322 RR they used a monocoque chassis, using the body frame as the torsional stability off which everything hung.
With the D3 and RRS, they decided to use BOTH! For increased on road stability the car had to be balanced perfectly and additions such as the hanging weights under the car simply to prevent body panel resonance were added, all increasing the car's weight. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #8582 Thu Dec 22 2005 9:36am
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
This is a very good question. So good in fact that I asked the chief designer of the vehicle (strangely called A Wheel) when he came to do a presentation of the Disco 3's launch last year (same floorpan, same weight issue). Basically he said that when LR set out to design the new vehicle they were determined that it would achieve certain pre ordained performance targets for saftey, torsional strength, suspension reach etc. As the vehicle developed through various prototypes the only way they found to achieve their targets was basically to keep on adding more and more metal to the floorpan. The implication was that if the design team had had longer to work on the job they could perhaps have started to engineer weight out of it. However using lighter but more expensive metal was too costly and they ran out of time. I wouldn't be surprised if a D3 / RRS "light" version was introduced in a year or two's time but for now we have one of the heaviest passenger 4x4's on the road but one that beats the competition in all those design criteria ways. Have you seen the Land Rover party trick where they balance a D3 or RRS on one front wheel and the oppisite rear wheel ? The body doesn't twist at all. Do that in virtually any other vehicle and you wouldn't be able to open a door for the amount of twist the vehicle would suffer. Mind you, one thing I have noticed is that the D3 and the RRS still don't seem to have been awarded an NCAP rating yet. I wonder whether the tests have not granted the vehicle the necessary 5 star result that the designers were aiming for .....?
Post #8695 Thu Dec 22 2005 9:57pm
thebishman
United States 2006 Range Rover Sport Supercharged Bonatti Grey
It's probably so damn heavy and safe it destroyed everything they ran it in too!! LOL!!
Bish '06 RRS S/C Bonatti Grey/Ebony/Cherry with RSE; PTI; Electronic Rear Diff and Sirius Sat Radio.
Post #8717 Fri Dec 23 2005 2:34am
They should try aiming it at Robin Sunpower........ that should earn it a full 5 *****
Post #8746 Fri Dec 23 2005 10:40am
