Home > Technical > access height
djsaad1
United States 2006 Range Rover Sport Supercharged Java Black
access height
recently the car has been havinig trouble getting into access height. It doesn't always happen but sometimes it will vibrate and struggle a little when it goes down. Is this normal?
Post #8558 Wed Dec 21 2005 9:45pm
kam100
mine does this sometimes, usually after a cold start, not had an error messages or any suspension air compressor failures as of yet, so presume its all good.
Post #8574 Thu Dec 22 2005 1:55am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Mine has not displayed this symptom but if there is no error messages then I would not worry about it.
I say to myself, that if I ask the car to raise or lower and it takes it's time, then there is a good reason for it, such as the compresssor is not charged enough, or the car is too busy doing other more important things! L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #8584 Thu Dec 22 2005 10:38am
