Home > Technical > Computer Reset when i Start the thing up.
kljw
Scotland
Hi
have noticed a small problem with my TDV8, that when starting, the centre screen goes off and the mpg reading (on the instrument display) is sometimes reset to zero. never had this problem on my RRS SC's or the wifes various TDV6's.
has anyone else exsperianced this? or have an answer?
cheers
keith
Post #163141 Wed Apr 02 2008 10:40am
Does it happen everytime you start? And then only at start time?
Post #163152 Wed Apr 02 2008 11:12am
kljw
Scotland
not every time i start, on occasion.
Post #163159 Wed Apr 02 2008 11:20am
It isn't right, whatever it is.... the reason for my question was that I was thinking maybe it was a fault that occurred only in particular temperatures (e.g. when it's really cold in the morning etc). Best take a trip to your dealer to get it checked out Confused
Post #163164 Wed Apr 02 2008 11:23am
kljw
Scotland
think i will. no set temp range and purley random. the only constant is that when i start the engine, the centre display goes off and resets.
thanks anyway
Post #163169 Wed Apr 02 2008 12:24pm
Steve in germany
Ok, is this happening when you put the key in the ignition, the systems start up but if you then start the car before it all comes on the systems go off and re-start again. Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #163208 Wed Apr 02 2008 6:45pm
Tim in Scotland
Freelander2 suffers this problem a lot too if you read the Freel2 forums 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #163229 Wed Apr 02 2008 7:35pm
us Fl2 owners have a similar problem
The mileage clock on ours spins round and resets the trip computer and all the dials back to zero,
we just get told its a software problem and a update sorts it.
The cold temperature effects some of the FL2 too, I and some others get a message the HDC is switched off and there is a fault. On mine this always coincides with the glowplugs coming on when it been stood overnight in the very cold. I think its battery charge related, others have been told it a sensor
Typical dealer, no fault code etc etc etc no fix for the latter
Post #163235 Wed Apr 02 2008 8:40pm
